Spare m50- m50b32?
Cook318IS
Wed Dec 15, 2010 5:22 pm
As most of you probably know my non vanos m50b25 was verging on death by timing chain before i put my m52b28 in. I want to strip it down becuase i've always wanted to strip an engine down anyway. The engine has no sump, no inlet, the wiring loom is scrap (bits donated to the m52 :D) and obviously it has a knackered chain.
So... do i strip it down and then make something awesome like a coffee table out of it. Or do i rebuild it as a 2.5 becuase i'd like to give that ago too - but i dont want to go back to a 2.5. Not much point bunging a 2.8 bottom end on and i'd rather have a vanos iron block if i was to do anything like that anyway. I'd love a turbo but insurance probably won't agree!
Discuss :D
Wed Dec 15, 2010 5:28 pm
sell the head ?
blitz877
AKA ajm-e30
Wed Dec 15, 2010 5:31 pm
didn't dezzy build his 3ltr from a 2.5 m50? that could be a good build for you
Cook318IS
Wed Dec 15, 2010 5:33 pm
magpie wrote:sell the head ?
Selling bits is always a possiblity. Or more likely is that it would end up getting stashed away becuase i can't be bothered with timewasters.
blitz877 wrote:didn't dezzy build his 3ltr from a 2.5 m50? that could be a good build for you
As i said, i'd rather have a vanos engine if i was to put a bigger bottom end on. But yeah it would be possible.
BrewCity11
Wed Dec 15, 2010 5:46 pm
Turk
blitz877
AKA ajm-e30
Wed Dec 15, 2010 5:50 pm
fast road/race engine?
Cook318IS
Wed Dec 15, 2010 6:00 pm
It would have to be a road engine becuase the e30 is my daily. I'm thinking more and more of doing it into something like furniture becuase i either want a vanos engine or to be a few years older for the insurance to be resonable for what i would like.
Dezzy
CR24v it's a lifestyle
Wed Dec 15, 2010 6:15 pm
Strip it
Prep the iron block ready for 30lt bottom end. there is a couple of ways to do this.
Then bolt your vanos head and sump etc off your m52 and you are at my spec give or take some s52 cams and enlarged tb :cool:
Wed Dec 15, 2010 6:59 pm
Blocks are the same Paul 8)
**BANNED**
Wed Dec 15, 2010 7:08 pm
Best of both worlds;
Strip and re-build the head ready for your proposed turbo project.
Strip and paint the block,then use as a coffee table in the short term.... :D
Youth is wasted on the young.
Cook318IS
Wed Dec 15, 2010 7:56 pm
DanThe wrote:Blocks are the same Paul 8)
I feel such a twat now :hammer: You used an e46 330i bottom end and an m52 loom + ecu iirc? Because this engine will need a new loom anyway :chuckle:
Oh and dezzy i already have an enlarged tb, but the butterfly valve is fooked so i need to obtain / make a new one.
Dezzy
Wed Dec 15, 2010 8:00 pm
Dan's is a E46 330 crank in a M52 block iirc
Cook318IS
Wed Dec 15, 2010 8:02 pm
Dezzy wrote:Dan's is a E46 330 crank in a M52 block iirc
No m54b30 pistons?
Dezzy
Wed Dec 15, 2010 8:06 pm
No standard 84mm M52 I think? I think the B30 has the same size pistons. A 330 crank in my donk would be nice. :cool:
Cook318IS
Wed Dec 15, 2010 8:24 pm
M54b30 pistons look to be 84mm according to an excel document i have. It also says that the torque from a m54b30 is 214lb/ft, mines already got more than that :chuckle:
Dezzy
Wed Dec 15, 2010 8:25 pm
Emissions strangled though as standard mate.
Cook318IS
Wed Dec 15, 2010 8:32 pm
Thats true. It also appears that the m50b25 pistons are 84mm so i presume i could use them with the m54b30 crank?
Dezzy
Wed Dec 15, 2010 8:36 pm
Oh yeh M50 and M52 pistons are the same different rings though. It would be a shame not to fit bigger pistons. M43 pistons are 85mm witch would give you 3.2ish with a 330 crank. Bit of a block skim at the same time and you will have a blockbuster. :cool:
Andy325i
Wed Dec 15, 2010 8:38 pm
Cook318IS wrote:Thats true. It also appears that the m50b25 pistons are 84mm so i presume i could use them with the m54b30 crank?
I think the skirts are too high on M50 pistons?
Sure Dan will be along shortly.....
Cook318IS
Wed Dec 15, 2010 8:39 pm
I thought you needed custom crank stuff for 3.2's - isnt that what alpina did? Anyway i think you guys may have made a desision for me :chuckle:
Anyway, got a few weeks off from friday and i need to remove the head of the engine from the block to get it home from the garage and begin the uber long task of buggering something up 8O
Dezzy
Wed Dec 15, 2010 8:43 pm
I have 3.0lt with bigger pistons and 2.8 crank
Dan has 3.0lt from the crank
Put them both together and what would you get?
A cracking engine I reckon. Basically Dan alpina lump. :cool:
oldroydsr4
Wed Dec 15, 2010 8:54 pm
What ecu would you run a m54b30 cranked, m43 pistoned m50 on?
Dezzy
Wed Dec 15, 2010 9:21 pm
I am using M52 remapped on my S50B30 pistoned M52. If you could run S52 loom and Ecu that would work? Dan?
Wed Dec 15, 2010 9:33 pm
V12 is where it's at you pussys :)
Cook318IS
Wed Dec 15, 2010 9:41 pm
E30BeemerLad wrote:V12 is where it's at you pussys :)
Hurry up then :wink:
Dezzy
Wed Dec 15, 2010 9:44 pm
850i/Ci, M70B50 V12, 4,988 cc, 295 hp, 330 lb-ft
Not exactly mind blowing matey :wink:
Wed Dec 15, 2010 10:02 pm
The comparisons I've had from those that have driven them is that 3rd gear and floor it is like flooring a 2.7 in 1st.
A 150 shot of gas will liven the lazy turd up anyway.
Anyway, we would have moved on from fossil fuels before I get that one done, if it even gets started :D
**BANNED**
Wed Dec 15, 2010 10:07 pm
[quote="E30BeemerLad]
Anyway, we would have moved on from fossil fuels before I get that one done, if it even gets started :D[/quote]
Hmmmmmm,
save gas,fart in a bottle!
Cook318IS
Wed Dec 15, 2010 10:55 pm
Ive just checked out bmwfans.info and it says that the m43 piston is an 84mm piston ( http://bmwfans.info/parts/catalog/E36/S ... t_pistons/ )
but the m44 318is engine is a 85mm piston instead ( http://bmwfans.info/parts/catalog/E36/S ... t_pistons/ ) Any ideas what conrods to use?
Just incase i do happen to fall over some of these bits in the mean time :)
Morat
Wed Dec 15, 2010 11:16 pm
E30BeemerLad wrote:The comparisons I've had from those that have driven them is that 3rd gear and floor it is like flooring a 2.7 in 1st.
Could you build it up with two 2.7 conversions? :)
Dezzy
Thu Dec 16, 2010 7:35 am
Cook I stand corrected.
Speak to Dan mate he will know better than me. I used standard M52 rods with custom little bushes
Cook318IS
Thu Dec 16, 2010 4:53 pm
My excel document i have agrees with what you said though about the m43 pistons being 85mm. I wanted to check incase the iS engine had decent pistons in it :D
I'll send him a PM in good time if he doesnt see this first. As i said im in no rush atm, and it'll take me forever to do it anyway :)
Dezzy
Thu Dec 16, 2010 5:28 pm
Yeh Dan is the man to talk to mate.
M50B32 sounds damn cool to me.
I think Dan has some none vanos schrick's as well which would make it a proper screamer. :cool:
Cook318IS
Thu Dec 16, 2010 5:37 pm
Yeah i've seen the shricks on ebay - i fancy having a vanos head though tbh. It would be rude not to cam it while the engine is in bits.
