How to get my E30 lower?
Badger0068
Sun Dec 12, 2010 2:20 pm
I recently fitted a Jamex -60mm suspension kit to my E30 as the standard suspension was knackered. However the rear of the car still sits really high, hardly looks lowered at all. How can I get the rear lower? I heard somewhere mk3 astra springs may fit?
Thanks for any advice.
beemerbird
Sun Dec 12, 2010 2:31 pm
How long ago did you fit the new kit? It takes a bit of time for cars to settle down onto new springs.
mrLEE30
Sun Dec 12, 2010 2:41 pm
Or you have fit the touring or cab springs, in ant event lowering with springs only will normally result in the tail up.
e30-EVN
Sun Dec 12, 2010 3:09 pm
Not necessarily, I lowered mine on springs as a temp messure and the back sat lovely!
As said above ^, you have to drive the car around for it to settle properly, mine took about a week to sit where it should! 8)
HairyScreech
Sun Dec 12, 2010 6:27 pm
and dropping one of these on springs alone is likely to result in an accident the first time it rains hard.
Sun Dec 12, 2010 6:29 pm
cut de springz innit !
TouringTash
Sun Dec 12, 2010 6:31 pm
Nah cement
318i Touring
Sun Dec 12, 2010 6:44 pm
pull a couple of fat chicks :P
HairyScreech
Sun Dec 12, 2010 9:08 pm
or drive around with 4 mates.
seriously unless you have 6 pot touring springs on a 4 pot cab then you dont want to go lower. 60mm is already borderline fucking the geometry up. any more and your into council handles and drives like a dog territory.
the only way to properly go lower is to move the suspension pickups upwards a la the late DTM cars.
Sun Dec 12, 2010 9:47 pm
not mention sump changes :!:
TouringTash
Sun Dec 12, 2010 10:07 pm
Shhhh Mick.
Victims and all that winkeye
318i Touring
Sun Dec 12, 2010 10:10 pm
i know i've got a good 6-pot sump,
i dare say you have a couple winkeye
HairyScreech
Sun Dec 12, 2010 11:01 pm
iv got a pair now i think.......
Badger0068
Mon Dec 13, 2010 1:07 am
The kit has been on there for a few weeks now. Its nowhere near as low as I want it. There is still 2/3 inches of arch gap on the rear, I really want to tuck the wheels in the arches a bit more.
HairyScreech
Mon Dec 13, 2010 1:40 am
get some pics up, sounds like it might be a case of the wrong springs, a -60 kit should sit them right up in the arch, hell a -40 brings them damn near the rear arch.
BrewCity11
Mon Dec 13, 2010 11:02 am
Do you still have the spring pads in?
Turk
