Escort Mk1 body onto BMW Compact floorpan
e30shed
Thu Nov 18, 2010 10:17 pm
This fella is as mad as a badger, but I doff my hat to him
http://www.practicalclassics.co.uk/foru ... =1&t=12571
1988 325i SE h/c
Black sport leather, mtec suspension -60mm, LSD, tech1 steering wheel, chipped motronic 1.3 & numerous scabby bits R.I.P
2003 320d ES pov R.I.P Now in swirlflap heaven.
2001 330i SE MV1's
1987 M535i Alpine white
e30-EVN
Thu Nov 18, 2010 11:15 pm
re-post LOL, the guy is a bodge artist, check out the amazing welding skils LMAO
N cap rated car......... Not LOL
cecotto479
Caution Unreliable Seller
Fri Nov 19, 2010 9:21 pm
When asked "What's your best bodge?", he happily boasts, "....pumping sloppy body filler into a mini steering rack through the grease nipples, welding an 8x4 sheet of steel from sill to sill on a mk2 cortina, recutting tyres and then painting them black to hide the exposed cords, fitting a mini windscreen to a maxi and then filling the gap with lino, connecting the abs light to the fuel gauge, making headlights out of tin foil, filling a diff with banana skins, filling a renault 12 engine with melted grease and leaving it running to go through an auction, roller painting a car then shining it with parafin, pot riveting sills on then covering with body filler....christ, you name it, I've probably done it, and whats more, would probably do it again "
1981 E23 735i
StuBeeDoo
Fri Nov 19, 2010 10:02 pm
To coin a famous Bobby Robson phrase, he's as daft as a brush.
Fri Nov 19, 2010 10:14 pm
Great idea, to cut the whole back end off the floorpan and botch-weld it back up a bit higher.
Cut and shut at its finest :mad:
e30-EVN
Sat Nov 20, 2010 7:02 am
I know the chassis is a bmw but in my opinion 'not the best at all', the guy needs suspending from a tree by his nut sack for ruining what a skilled person could have made a nice escort.
:mad:
Sat Nov 20, 2010 3:12 pm
Not to mention ruining a perfectly good Compact :?
oldroydsr4
Sun Nov 21, 2010 7:27 pm
What a deathtrap.
Sat Nov 27, 2010 11:20 pm
Also on Retrorides
http://retrorides.proboards.com/index.c ... 423&page=1
And he intends to fit a V12 :eek:
leeparkes
Sun Nov 28, 2010 12:27 am
Speedtouch wrote:And he intends to fit a V12 :eek:
A V12 would rip this car apart.
02Man
Sun Nov 28, 2010 8:51 am
Well if the quality and strength of his welding is up to par,what's the problem?
After all ,every VW based beach buggy is based on a 'cut 'n shut' Beetle floorpan.
There's a big difference between glooping the back end of a car on to a right off with pigeon shit welds and an innovative custom jobbie like this,good luck to him I say :)
Sun Nov 28, 2010 11:10 am
cecotto479 wrote:When asked "What's your best bodge?", he happily boasts, "....pumping sloppy body filler into a mini steering rack through the grease nipples, welding an 8x4 sheet of steel from sill to sill on a mk2 cortina, recutting tyres and then painting them black to hide the exposed cords, fitting a mini windscreen to a maxi and then filling the gap with lino, connecting the abs light to the fuel gauge, making headlights out of tin foil, filling a diff with banana skins, filling a renault 12 engine with melted grease and leaving it running to go through an auction, roller painting a car then shining it with parafin, pot riveting sills on then covering with body filler....christ, you name it, I've probably done it, and whats more, would probably do it again "
Where did you find this? :D
If it was a non sunroof compact I would have been upset :)
Is this a home made compressor tank? :eek:
cecotto479
Sun Nov 28, 2010 12:18 pm
On the Practical Classics forum. The thread is about your best ever bodge or something similar. You get the usual, " I once cable tied the fan shroud on temporarily and forgot about it for nearly three weeks! OMG!" and, " I once used one of my girlfriend's stockings as a fanbelt on my Morris 1000. I had some quick thinking to do when my wife noticed 'cos she only wears tights. LOL" and then you get this guy's manic rampage through the MoT manual. Hilarious. Mini screen in a Maxi?!
Doesn't everyone use a 47kg propane bottle as an air receiver then?
1981 E23 735i
gare30
Wed Dec 01, 2010 9:30 pm
omfg just read the thread wat a bodged up peice of shite the biggest question is y? :eek:
mrLEE30
Fri Dec 03, 2010 2:38 pm
A m42 would rip this apart! I cannot understand why anyone would attempt this, cheaper to buy rusty old scort rather than build your own!
Ziggy
Fri Dec 03, 2010 3:23 pm
kingz
Fri Dec 03, 2010 3:27 pm
NUTTER!?
harry_p
Fri Dec 03, 2010 4:46 pm
have you seen what even completely rotten mk1 escorts are worth these days? a lot more than a decent running totally rust free compact anyway!
i like the idea, old school looks with modern dynamics comfort and running gear, but don't like the execution of this particular one!
cheers,
harry
dave525
Sun Dec 12, 2010 12:37 pm
i just like all the big talk. gonna fit a v12,just rip out the 1.8 and fit a 5.2 from a 750.goes straight in like all bm,s that have a straight six in them. dont know what gearbox,maybe a v8 one. wish it was that easy. his mot tester must be very brave too.wonder what the insurance would say as well
martinpallot
Sun Dec 12, 2010 3:13 pm
Seriously worrying, he's obviously punching high above his weight judging by the fact that he doesnt seem to be able to make templates and uses as many peices of rusty steel sheet to patch the escort body to the e36 floorpan. Problem is that anything can be made to look good with tubs of P40 and seam sealer in the right places :mad:
tonybtonyb
Sun Dec 12, 2010 7:19 pm
Talking about cut'n'shut the fella must love jigsaw puzzles :roll:
Sun Dec 12, 2010 8:05 pm
that blokes a Nutta!
mc_hawkings24
Sun Dec 12, 2010 9:54 pm
The back end being reattached seems abit erm iffy but the welds look fine as there seamed and not spotted. If the floor pan of the original shell was fine he couldve stuck with it ohwell seen worse.
Remember the kaddet c on honda s2000 chassis? looked alot better than this ted in the shed.
HairyScreech
Mon Dec 13, 2010 12:06 am
theres nothing wrong with it in theory, execution my now be the nicest, but meh.
Mon Dec 13, 2010 1:23 pm
So long as it's strong enough to withstand the immense forces that are going to be put on it, then all to the well and good. However, looking at the standard of fabrication work, it doesn't inspire confidence.
That said, even BMW with all their professional high-tech design can get it horribly wrong, for instance, the rear subframe mounts cracking on E46s (huge splits appearing in the floorpan), and the rear damper top mounts on E30s cracking off :eek:
Wed Apr 06, 2011 12:09 am
Wed Apr 06, 2011 10:59 am
Indeed, nice Calypso 530i's with mushroom leather will probably be worth a fortune in ten years time! :mad:
And why go to the effort of dropping in an M30B30 when, for the same effort, you can have the meatier M30B35?
