Barton's E30 Project - ON EBAY!
Barton
Post Fri Oct 29, 2010 11:25 pm
Thought i'd start a proper thread on the car
so far:
couple of quick pics on the phone of the 320i
picked up a 2.5
plan is to fit it next weekend
the engine is/was filthy and had quite a few leaks (oil over absolutely everything), so i've ordered a complete gasket set and some head bolts to give it a mini freshen up
whilst i'm waiting for the bits, i made a start cleaning some parts
inlet side of engine:
some smaller parts:
took off and cleaned the t/b and oil fiter bracket
removed the exhaust manifold
started to clean up the exhaust side of the engine
sooooo much oil. dont really know where its all come from
thans for the comments guys
here's some more progress on the e30
Cleaned up the inlet manifold, fitted with a new fuel pressure reg and 6 cleaned and tested injectors, new gaskets, and a properly cleaned t/b and icv
Cleaned the insides of the airbox and maf unit, new gasket fitted (new filter to go in)
front of block stripped, revealed the cam seal letting oil out
de-greased (cam seal has now been removed, awaiting new seal when rebuilt tomorrow, half moon seals have been re-sealed with hylomar)
rear of head also seems to be leaking, i've re-sealed the half moons
Head removed from block, for new headgasket to be fitted, rocker cover gasket was also leaking so this will be replaced
collected a few bits for the rebuild / swap incl z3 short shift conversion
plan for tomorrow:
get engine rebuilt, and the e30 stripped
plan for sunday:
new engine in
Kemix
Post Sat Oct 30, 2010 12:13 am
Lots of goodies! Good luck on sunday mate 8)
Felix79
All loved up !
Post Sat Oct 30, 2010 12:25 am
Xmas come early.
Good luck with the open bay surgery winkeye
Felix79 aka Dan
E85 Z4M Roadster
Duke137
Post Sat Oct 30, 2010 12:37 am
Quick question, how have you cleaned the block?
Looks good, keep us posted!
Barton
Post Sat Oct 30, 2010 9:14 am
wire brush, petrol, white spirit, gunk degreaser, fairy liquid, etc etc just a combination until it was all clean
Barton
Post Sat Oct 30, 2010 11:42 pm
Well a bit of a weird update, nothing really went as planned
the back of the head was leaking through the plug, i suspected it was cracked, so tried to find a new core plug, which after being told the wrong size and having to go and get another, we replaced this.
on further inspection of the head, if appears the valves and valve seats need to be re-seated, and a general clean up, steve kindly started to strip the head, but we found it quite a difficult task (the haynes manual is shite)
steve is going to remove the valves and do the clean/ re-seat at work during the week (thanks dude)
we also found one lobe on the cam to be worn a fair bit more than the others, so no sure what to do about this.
sump was removed and cleaned, re-fitted with a brand new gasket
old auto flywheel removed
painted the block
painted inlet manifold, timing belt covers, exhaust manifold, and a few other bits with VHT paint
so basically waiting until next weekend to re-assembe the head, fit it to the bottom end, re-assemle the rest of the engine and fit it into the car.
Post Sun Oct 31, 2010 12:27 am
I think I would be getting a pressure test done on the head before going any further, just to make sure you're not investing money into something that is going to bite you on the arse.
oomz1975
Post Sun Oct 31, 2010 10:25 pm
E30BeemerLad wrote:I think I would be getting a pressure test done on the head before going any further, just to make sure you're not investing money into something that is going to bite you on the arse.
This, keep us updated.
Barton
Post Sat Nov 06, 2010 8:13 am
head has cleaned up like new, so with the valve reground should be mint
i've done a bit more whilst steve's got the head
cleaned the loom
bolted a few bits back onto the block
painted the rocker cover
then rubbed back the raised bit
Alpina99
Post Sat Nov 06, 2010 8:24 am
Looking good,
Keep the photo's coming,
Gone, but not forgotten !!
Barton
Post Sat Nov 06, 2010 9:48 pm
this is the stage we got to today, big thanks to steve for sorting the head
Andyboy
Alpina Colada
Post Sun Nov 07, 2010 1:59 pm
Looks good. I'd keep it looking stock - bottletops, 320i badge etc and keep the 320i diff. That''ll p1ss a few thrusting w@nkers off!
Dezzy
CR24v it's a lifestyle
Post Sun Nov 07, 2010 8:37 pm
Good attention to detail.
Nice Looking motor :cool:
Barton
Post Sun Nov 07, 2010 9:52 pm
todays update
we finished assembling the engine, fitted new timing belt and tensioner, waterpump, temp senders, adjusted valve clearances etc.
plenty of seized bolts etc, and just generally taking the time to tidy the engine up as it was going back together slowed progress. that and the fact that when we got the engine out, we realised the clutch had seen better days, but couldn't get a replacement, being 3pm on a sunday
so until next weekend i'm left with this:
and this
over the week, i'll give the engine bay a tidy up (try and sort the leaky PAS reservoir and hoses), clean the gearbox, fit the Z3 short-shift and new gear linkage bushes, and get the final few hoses on the engine
Barton
Post Sun Nov 07, 2010 9:54 pm
oh, and i noticed there is actually some play in the steering guibo, i reckon its a good time to get to it and replace it, do bmw do a kit that includes new bolts to replace the rivets?
Barton
Post Wed Nov 10, 2010 11:00 pm
bought and fitted a new clutch
took the rest of the gear linkage out to replace all the bushes, and fit the z3 shifter
cleaned up gearbox, fitted new mounts
fitted a new steering guibo, has taken a lot of play out of the column
gave they bay a quick clean
have also fitted a new guibo to the back of the gearbox, and re-attached the slector rod with new joints, and fitted the z3 shifter into the car with all new bushes
tonight i removed the propshaft centre bearing (eventually) and am awaiting a replacement
aj_mckay
Post Thu Nov 11, 2010 9:14 am
Proper job 8)
Barton
Post Sun Nov 14, 2010 2:07 pm
engine in
bonnet on
got a bit of a random oil leak coming from somewhere i cant see, could be the cam seal, which was replaced, if it stays like it is (minor leak) i'll leave it for the time being
if it gets worse, i'll have to strip a few bits out to have a look and maybe re-seal it
bridgemond
Post Sun Nov 14, 2010 2:27 pm
Good work man. She coming along nicely :D
Barton
Post Sun Nov 14, 2010 2:36 pm
first test drive in a minute, i shall report back
Barton
Post Sun Nov 21, 2010 8:03 pm
Whilst trying to source the oil leak on the engine, i got to here:
having found this on the cam seal
i made up a new o-ring and slapped a load of hylomar around it before re-fitting
no more leak :D
db8
Post Wed Nov 24, 2010 8:40 am
nice! :cool:
Barton
Post Wed Dec 08, 2010 8:52 pm
Smashed it :(
the abs on these is pretty crap
just slid into the back of someone
need:
o/s front wing
front valance
complete front grill
o/s headlight wiper
front bumper
o/s front indicator lense
hopefully havent damaged anything else although the o/s headlight has been pushed back about an inch at the top
toby
Post Wed Dec 08, 2010 9:08 pm
Oh bad luck! Hope you get the bits sorted easily.
andrew320i
Post Wed Dec 08, 2010 9:47 pm
That engine is looking sooo clean, top job! 8)
kman82
Post Wed Dec 08, 2010 9:51 pm
No way! Was it on ice?
Ive just seen this thread and read through, did the engine fire up first time? I'd love to do something like this with mine bit think that's a bit optimistic!
Barton
Post Wed Dec 08, 2010 9:59 pm
its just wet and cold out, and the area i live in is a joke with roadworks and temporary traffic lights
yeah, fired up on the button
kman82
Post Wed Dec 08, 2010 10:20 pm
After all that hard work, I feel your pain. Oh well good excuse for a paint job?
Barton
Post Wed Dec 08, 2010 10:43 pm
i wish
i dont have the money, i need to do this as cheap as possible
Barton
Post Sat Mar 19, 2011 7:42 pm
tonybtonyb
Post Sat Mar 19, 2011 8:44 pm
A top job there :cool:
Barton
Post Sat Mar 19, 2011 9:48 pm
thanks, will be a shame to see it go, but i need to get my other projects on the move again
brian_s
Post Tue Apr 12, 2011 10:20 pm
Any pics of the damage? :mad: and you still got the old bonnet?
Barton
Post Wed Apr 13, 2011 5:54 pm
nah, bonnet went, it was fucked when i bought it
