I think I have the wrong one.
I've measured up today and my sump has a 14mm hole but the dipstick tube seems to be 15mm. (by vernier caliper)
Please can someone confirm sizes or measure their dipstick tube for me? Thanks.
E34 dipstick tube
blue30
I'm struggling to remember but isn't there a bulge near the bottom, it only goes in up to the bulge with an O ring on it so the last bit might be slightly narrower?
gudgeon
I measured from the very bottom of the tube, the bit that has to go in. Yes there is a bulge further up.
From realoem virtually all dipsticks seem to be 14mm, or at least the diameter is not given but the o-ring is usually listed as 14mm. I wonder what the hell I have? might start looking at the diesels.
I would have said you might have an M52 tube, but these are quite a bit bigger, around 5-6mm, as they incorporate a drain.
It might be M20 or something entirely different
gudgeon
I'll take a photo of it tonight and you can all play "identify the dipstick"
It's got an interesting bracket attached to it that has a bit of pipe joint on it. Looks like a fuel line joint but I can't really believe that would be a good idea. Anyway, I may try my spare M20B20 tube in the hole to test fit and possibly to use as a backup in case I can't source the right part in time.
Sounds like an E34 M50 tube to me...
gudgeon
You're quite right it is.
The explanation is that I should take a closer look before taking up your time on here.
The guide tube is 15mm, and so is the hole if you hook out the hardened old o-ring still stuck inside!
It now fits in easily.
gudgeon
Well I "identified the dipstick" -- it was me all along!
