mounting engine solidly?
deian
Post Fri Oct 07, 2005 4:17 pm
is this a stpiud or interesting question? SAY you mount an engine solidly (i mean no rubber bushings) onto the chassis/shell of ur car, what would be the good/bad effects?
thanks,
Deian
Toby_Unna
Boost Junkie
Post Fri Oct 07, 2005 5:05 pm
a lot of vibration, and i mean a lot. it's not a good idea for road use.
racing cars have stiffer/solid mounts, presumably to get better throttle response because the engine twists less when you put your foot down
dazleeds
old skool raver
old skool raver
Post Fri Oct 07, 2005 5:17 pm
i think youd find you had a very bad headache within minutes mate
the vibration would be very severe without the rubber mounts and bumps in the road would possibly rip the mountings out of the chassis
i wouldnt fancy trying to drive anywhere but on a track in it to be honest and it may even be too harsh for that :clin:
www.oldskoolfantasy.co.uk
deian
Post Fri Oct 07, 2005 7:58 pm
now i see :D thanks
JungleGus
Post Sun Oct 09, 2005 5:34 am
urethane engine and tranny mounts work well for me...nice compromise, i dont find em too harsh to use on the road. they also prevent the engine moving and damaging stuff......like radiator lines if one shears, or parts of a turbo setup if you had one.
www.bmw2002.com
E327UKL
Post Sun Oct 09, 2005 8:02 pm
i used solid engine mounts on my 20l 16v xe engine, they wer nt too bad other than the fact that it would shear bearbox housings! :? go poly :D
