particulate filter on a diesel + black smoke question
blingsta
Boost Junkie
Post Fri Nov 19, 2010 6:30 am
anyone know if this is a big job? been advised to change it on my E53 X5. What are the benefits of doing this please?
Plus, is it normal that when you plant your foot, it smokes like crazy? i thought you should get a puff of black smoke then it clears up? but mine seems to chuck smoke out constantly on full throttle ?
Any advice will be greatly appreciated :D
Post Fri Nov 19, 2010 7:42 am
blingsta wrote:Plus, is it normal that when you plant your foot, it smokes like crazy? i thought you should get a puff of black smoke then it clears up? but mine seems to chuck smoke out constantly on full throttle ?
Check your turbo hoses - even a small split in one of the pipes will be amplified massively when it comes on boost causing it to overfuel and chuck out the black smoke when under load.
irish320i
Post Fri Nov 19, 2010 6:07 pm
Its very unlikely your particule filter is causing this problem has the oil system breather filter been changed recently I have seen these block and cause massive amounts of smoke on the e46s.
Al
89 316i s50b30, 00 subaru imperza turbo(gone) 2005 range rover td6,
blingsta
Boost Junkie
Post Sun Nov 21, 2010 2:04 am
irish320i wrote:Its very unlikely your particule filter is causing this problem has the oil system breather filter been changed recently I have seen these block and cause massive amounts of smoke on the e46s.
im gonna give it a full service very soon, should hopefully do the trick
dave525
Post Wed Dec 01, 2010 1:48 pm
price up a new particle filter. best be sitting down. :eek:
kieran325
Post Wed Dec 01, 2010 1:53 pm
dave525 wrote:price up a new particle filter. best be sitting down. :eek:
Indeed, I heard about this in the dealers a few weeks ago. I had to sit down and I wasn't buying one 8O
I heard that most E60's when they reach 60k - correct me if I'm wrong, need to be done.
irish320i
Post Thu Dec 02, 2010 8:04 pm
Haven't seen them give that much trouble on the e60s look after quite a few with well over 100k on them, think its down to them getting plenty of long distance driving there is a couple of companies here that will write the dpfs out of the ecu allowing it to be bypassed
Al
