Cooks m52 316i - going S54!
Post Sun Nov 28, 2010 11:12 am
I've never had my M52 with the stock manifold fitted so was never able to compare the before & after. I remember Omi wasn't too enthusiastic about the M50 inlet after he did the swap, he felt it lost a fair bit of bottom end.
Where do you notice the difference?
Cook318IS
Post Sun Nov 28, 2010 11:21 am
eko wrote:
Cook318IS wrote:Woop woop! The vibration has gone :eek: So it was my rear springs causing all my problems! I've taken it for a lovely little drive this morning, the manifold hasnt made as much as a difference as i thought it would but its still noticable! I've also come to the conclusion that my idle control valve has had it :chuckle:
Rad bled up ok?
Yeah it seems to have done. I left the heaters on while i took it for a drive and it didnt even go much above the 1/4 mark! That rad is actually bigger than the oem 328i aircon spec rad - its thicker!
E30BeemerLad wrote:I've never had my M52 with the stock manifold fitted so was never able to compare the before & after. I remember Omi wasn't too enthusiastic about the M50 inlet after he did the swap, he felt it lost a fair bit of bottom end.
Its a bit more lively at the top of the rev range and i have lost a little bit of torque. But its lagging abit between gear changes and the idle isn't perfect so i think the idle control valve is sticking. (despite being cleaned before being fitted)
Post Sun Nov 28, 2010 12:53 pm
it takes a little time for ecu to adjust to the manifold. then they really fly
Cook318IS
Post Sun Nov 28, 2010 12:54 pm
True, i hadn't thought of that. Maybe my icv is ok then :D
monkey
Post Mon Nov 29, 2010 9:25 pm
how is it running now Paul ? when i changed the manifold on the Mrs e36 for an m50 one she also noticed less low end torque . i found it much better above 4000 rpm though :D
Cook318IS
Post Mon Nov 29, 2010 9:29 pm
Its not running too badly at all to be honest. I think it is getting better too. But yeah above 4k and its pretty awesome!
I've still got your box of pipe bits and pieces here too btw. Give me a shout if you want me to drop it round or if you want me to hang onto it until the rolling road meet.
monkey
Post Mon Nov 29, 2010 9:32 pm
just hang onto to it as i dont need it at the mo . should be good to see how it does on the rollers now .
Cook318IS
Post Mon Nov 29, 2010 9:34 pm
:thumb:
Yeah it will be pretty interesting considering how good the results were before the manifold! I've got a beautiful bit of stainless now for my fuel rail bracket too - my dad made it for me :D
What was the inlet rubber boot you said to me too? e36 325i?
monkey
Post Mon Nov 29, 2010 9:41 pm
yea i had to use an e36 325 one to get my m30 air box to fit .
Jozi
Post Tue Nov 30, 2010 1:45 pm
Cook: what tutorial or guid or what ever did you use when doing the m50 manifold swap? I have one to go onto my engine as well once I get dropped into the touring.
Cook318IS
Post Tue Nov 30, 2010 8:01 pm
Jozi wrote:Cook: what tutorial or guid or what ever did you use when doing the m50 manifold swap? I have one to go onto my engine as well once I get dropped into the touring.
http://www.e30zone.net/modules.php?name ... 0+manifold
Its very easy to do tbh. Although i found i couldnt use an m50 throttle becuase the throttle cable kept falling out - despite it being fine when it was attached to the m50 engine when it was in the e30 :screwy:
Jozi
Post Tue Nov 30, 2010 11:16 pm
Thanks, I'll bookmark that for future reference so! Looks to be better than any others I've seen so far. I have a E34 525 throttle cable on my list of things to get though?
Cook318IS
Post Tue Nov 30, 2010 11:18 pm
Yeah, its a simple but good quide :D The throttle cable is fine, its the throttle itself that was the problem due to the design of it.
Jozi
Post Tue Nov 30, 2010 11:20 pm
I'll have to look into it and hold of getting it bored out as well then. I'm still weeks if not months away from putting the engine in, never mind doing the m50 swap (want to get it running 1st before doing more work).
Cook318IS
Post Tue Nov 30, 2010 11:23 pm
Jozi wrote:I'll have to look into it and hold of getting it bored out as well then. I'm still weeks if not months away from putting the engine in, never mind doing the m50 swap (want to get it running 1st before doing more work).
Thats what i did - i got it running and got it dynoed as standard so i knew where i stood before doing any mods :D
Bring on januarys rolling road day :D 5th rolling road day for this car i think since its been on the road last september :?
Rallyprep_UK
formerly Driftnething
Post Tue Nov 30, 2010 11:45 pm
Image[/quote]
Thats what I have and I scoured ebay for it !. A cracking unit :wink:
Loving the car, just reading the whole build now ! I met Andy (obs). You guys cant be that far from me ?!
I plan on taking my B28 E30 to A.Jeffreys in the early months after christmas before its "ring" thrashing !!!
dont fancy a drive to germany do ya boys !!!???
Racing is living, everything else is just waiting...
http://www.rallyprep.co.uk
Jozi
Post Tue Nov 30, 2010 11:48 pm
I have it all ahead of me :) Dyno as is is on the cards before any mods come near the car.
Cook318IS
Post Wed Dec 01, 2010 8:05 pm
Driftnething wrote:[
I love my headunit :D
Andy is up north atm, but yeah we were local boyos. As you can tell from my location im from torquay. Are you taking you're b28 to the bmw rolling road day that has been organised in january- total bmw magazine will be doing a feature :D
You might want to resize your avatar a tad too, tis rather large :chuckle:
Rallyprep_UK
Post Wed Dec 01, 2010 8:33 pm
haha ! I did not check my avatar after adding it !!!
now changed :mad:...
The only thing about that headunit is - I have not worked out how to turn down the brightness yet and at night the car lights up inside !!!. I just push the button for the face to flip down until I can be bothered to download a user manual and have a proper look ! LAZZZZZZZY.
I know nothing of this rolling road day ?!
My car might just be built by then but I doubt I will take it if its early in January (awaiting a flywheel and then need to fab my exhaust manifolds), Oh and uuuurm paint it ! I could take it as a multicoloured E30 but would rather wait in all honesty !
Cook318IS
Post Wed Dec 01, 2010 8:44 pm
This one - http://www.e30zone.net/modules.php?name ... c&t=183477
There is an option which dims the lights on the stereo when you turn your car lights on. if i remember correctly you have the ignition / engine on, turn the stereo off and press and hold function (i think!) then go through the options until you find dimmer and turn it on :thumb:
Why not come along anyway even if the car isnt ready? It should be quite a good day :D
Rallyprep_UK
Post Wed Dec 01, 2010 9:06 pm
Thanks for the info I will try that :wink:
That roller day looks great !
Just spoke to a friend from further down who is going too so ideal ! Look forward to it and just have to get a move on with my machine and see I suppose...
I'm there :cool:
Cook318IS
Post Sat Dec 04, 2010 12:04 pm
I still have a bit more camber on one wheel than the other, and i still have a slight vibration :x I think i need to investigate wtf is going on with that rear wheel!
mark_rs
Post Sat Dec 04, 2010 1:35 pm
its a bit of a old convo but.
There jap cars are fine. but people dont look after them.
i was running a 350bhp s13 200sx for about a 2 years.
Engine rebuild every 6 months.
oil flush, oil, oil filter, plugs, about every 4 month
ya gotta think the s13 is only a 1.8 with a fair size turbo
and useing it at pod on there drift days.
what are at the start and end of every month.
you can run in to a right part's list. £££££'s.
Cook318IS
Post Sat Dec 04, 2010 3:53 pm
mark_rs wrote:its a bit of a old convo but.
My mates s13 isnt much different. Hes estatic that his norris designs built engine has seen 7k miles :chuckle:
I'm more and more tempted to keep mine anyway, but i have initially sorted out a photoshoot with an s14a 200sx and a little trip in it.
mark_rs
Post Sat Dec 04, 2010 4:25 pm
thats right you know they dont last long.
nice one on the photoshoot
take a good look at your subframe bush's drifting
dont do them any good.
Cook318IS
Post Sat Dec 04, 2010 4:36 pm
All the bushes are only year old on this car and they are all direct from bmw, and to be honest the car isnt driven that hard. So the bushes should be ok. Once the weather has bucked up i think im going to need to jack it up again and inspect everything... again
mark_rs
Post Sat Dec 04, 2010 4:41 pm
yer best to keep it all in top nick.
just take your time when looking
as i say drifting can do some right damage.
Cook318IS
Post Sat Dec 04, 2010 4:42 pm
I don't use the car for drifting. Tbh its only used to take me to and from work about 7 miles away, and taking me to college.
mark_rs
Post Sat Dec 04, 2010 4:45 pm
Cook318IS wrote:
Long story short, its sat outside my house after a fuel leak 2 weeks ago and hasn't moved. Battery has now died from being sat for so long and trying to crank it over to see if the fuel pipes are the right way around. It now obviously won't start and i have a strong dislike of working in the cold at this time of year. I have also noticed that one of the rear wheels has more camber than the other side :? All bushes are from bmw and about a year old :?
After a drift day today im tempted to get a skyline or a 200sx, i need boost :cry:
fair play.
Cook318IS
Post Sat Dec 04, 2010 4:46 pm
I didnt do the drift day, i was taking photos. Seeing boosted jap turbo cars made me want one.
mark_rs
Post Sat Dec 04, 2010 6:27 pm
o see. yer they are good. i'm after a rx7 but its finding a good one.
Cook318IS
Post Tue Dec 21, 2010 4:55 pm
So today i've began stripping down the old m50b25. I've always wanted to strip and rebuild and engine so i may aswell make the most of it and build a 3.0/3.2 engine :D. So this is what i started with - my old m50, on its side, no sump, no oil filter housing, no alternator, no power steering pump, no exhaust and alot of the loom missing.
So there i was happily removing the coil packs and the spark plugs when i got to the third cylinder and quite a bit of water came out and i was greeted with this spark plug...
Nice :?
The were all the plugs as they came out (front of the engine on the right)
After a while i was left with this...
After a bit more spannering...
Then voila! One head off a block...
I'll give a guess which cylinder that spark plug belonged to!
I took a quick ganders at the head gasket and it looks fine, and the engine never overheated when it was in my possesion.
wullie325i
CAUTION - unreliable trader!
Post Tue Dec 21, 2010 5:10 pm
mark_rs wrote:o see. yer they are good. i'm after a rx7 but its finding a good one.
loads of good ones about at the moment if your serious but you need to spend a few £££ 5k+ imo.
been hankering for one for quite some time nearly bought a pink one a few years back winkeye
wullie325i
Post Tue Dec 21, 2010 5:13 pm
thats a sludgy mess in there indeed. what was the cause?
im thinking on the same lines as you with a 3.0 or 3.2 in the future.
Cook318IS
Post Tue Dec 21, 2010 5:16 pm
Im not sure of the cause, like i said the head gasket looked ok, but i'll have a proper look when its not so dark! I can't imagine that all of that is from moisture and surely all the other cylinders would be the same if it was from moisture.
Edit: just had a thought, it was stored outside for a while until it was moved to the garage, but it was covered up - still a possibility though i suppose.
