Help and recomendations with system
_Jay_
Right my head is propper swimming about all over the place at the moment. Im looking at what speakers to get for my cab, but having an info overload.
Im looking to put two subs in the boot. After looking at the type of music I listen to, I have been recomended to have two 12" subs, stood upright so they can be put under the hood compartment to still leave space. Seen a few pictures and it will leave enough room for anything else I need in the boot.
Looking to get the two 12" Alpine Type R subs, what amp would you recomended to power these?
Ive been looking at some components for the front kickwell and for the rear door cards, and looked at the Vibe Black Air 5 V2's, anyone had any experience with these? If I was to put these in the front and back, will that give me sufficient amount of sound upfront? What components would others recomend to use up front and powered off what amp?
And I know some people make a custom door build etc, but because I have a full custom leather interior, I dont fancy cutting up the door cards, especially when I wont be able to get the leather to match. So I was thinking for a bit more sound, could I maybe do something under the front seats?
Any help is much appreciated!
e30maddog
i also have custom door cards, but it didnt stop me from cutting my way into 6.5'' components
i dont know what others think but i dont think 5'' components will give enough drive unless ofc you go for the high ££'s competition jobbies. remembering that bass kills off treable too. i would go for a 6.5'' component and put em in the lower/lock side of the door, there is enough space without needing to cut any metal there. i wouldnt worry about needing leather to match coz once you have a speaker in there it wont be comming out again ^^ the setup id go for is 5'' in the kickpanel and rear cards with the 6.5;; in the doors, 2x 12's in the rear and you will be kickin
_Jay_
Im really against cutting in to them at the moment though lol. Is there any way I can maybe get a set of 6.5" to fit the front kick well?
e30maddog
passenger side will be easy enough, its the driver side which will give a problem. with the under seat option, you would have to have the seat at its highest p[osition at all times and you will have flow issues too, i wouldnt go for that myself. you dont have many options tbh, maybe you could use a spacer against the kickwell so you can use a 6.5 in there, you would probly need a good 1'' spacer though, and the speaker would be rely close to the accel pedal
e30maddog
or even if you are good with a saw and mdf.. you could maybe make a slanted box which could sit at the end of the seat rail, right below the front of the seat? as a last resort ofc over cutting door cards
I plan on this setup for my cab as i want something thats loud and clear
A set of comps with tweeters in bmw tweeter pods in the front
a set of comps in the rear
have the comps running from a 2 channel amp
then have a mono or bridged amp with 2x 8" subs
thats 10 speakers
thats 10 speakers
TouringTash
running two pairs of components off a two channel amp requires careful choices. Look at impedance values fella.
318i Touring
You have lost me nowTouringTash wrote:running two pairs of components off a two channel amp requires careful choices. Look at impedance values fella.
i understand OHM and RMS and thats it
are you basically saying a 4 channel would be better suited because of some technical shizzle
- E30 Zone Meets/Events Team
It's his wish list Jason.
e30maddog
you will need full control of setting for each set of comps, if you are useing an amp to power 2 diferent sets of comps on the same amp settings you may be overpowering 1 set and underpowering another.. unless all the comps are of the same make/value...
oh i got you, i was going to get 2 sets the same anyway either that or just a pair for 13cm speakers for the rear. i would get both the rears and front with the same RMS as the amp anywaye30maddog wrote:you will need full control of setting for each set of comps, if you are useing an amp to power 2 diferent sets of comps on the same amp settings you may be overpowering 1 set and underpowering another.. unless all the comps are of the same make/value...
bmw9818
if you want smooth bass and pure sound quality go for jl audio, if you want insane sub with a crazy bass note go for ground zero, ive heard many others kenwood, jbl e.t.c previously had an splx sub, the jl w7 is 50x better than any sub ive heard! go to an audio shop and ask for a demo or something,
in the front ive got ground zero (budget ) speakers no point in getting anything expensive as wont make muc of difference, rear ive got 6x9 ground zero hydrogens in a custom box behind headrest,
as for the speaker under the front seats thats actually a pretty good idea to get a bit more sound in... you can make it happen if you want to
you sit in the front, surely you want decent speakers in therebmw9818 wrote:if you want smooth bass and pure sound quality go for jl audio, if you want insane sub with a crazy bass note go for ground zero, ive heard many others kenwood, jbl e.t.c previously had an splx sub, the jl w7 is 50x better than any sub ive heard! go to an audio shop and ask for a demo or something,
e30maddog
Focal K2 power for exampleAlex wrote:you sit in the front, surely you want decent speakers in there
not a lover of door builds howevere30maddog wrote:Focal K2 power for exampleAlex wrote:you sit in the front, surely you want decent speakers in there![]()
these take my fancy but some how the price tag puts me off
http://caraudiosecurity.com/shop/produc ... 11507.html
HOW MUCH
I've got some front door card builds and just about to purchase some rear door cards one as well.
About 12 speakers so far
e30maddog
jezzz %&£$... i think i might spend a few hours a day in the shed building more of my door cards.....
TouringTash
All electricity is is electrons being pushed along a cable so an amplifier 'pushing' electrons to a speaker comes up against a resistance, measured in ohms. So if two speakers are connected to one set of outputs the amp has to work twice as hard for the same output. Hence the amp will get hotter and if the components are not up for the job (and most are not no matter what make) its meltdown time.
Better off with a 4 channel amp although space then becomes a problem. Maybe two small 2 ch amps under either seat.
As for which speakers up front, this becomes a personal choice as I would still fork out a ton for comps up front, which in some eyes is silly and a waste. The location and space for the fronts is poor sound wise, well it is a car not the bbc radio theatre but poor speakers in a poor location are well poor but good speakers in a poor location will sound better and with a cheekie EQ tucked out of the way can pay SOME dividends.
JAY stick with Rockfords and you'll never go wrong.
318i Touring
TouringTash
no door handle trim?e30maddog wrote:Focal K2 power for exampleAlex wrote:you sit in the front, surely you want decent speakers in there![]()
And get that fence finished
nice set up mind
318i Touring
Alex, you want 2x12" in the boot
TouringTash
nah 1 15" see how well E30s are built then.
ftw http://www.lean-business.co.uk/eshop/em ... p-785.html
that beat will push 35Hz and more than an E30 can handle.
Then you start messing about with resonant frequencies, which is nice.
a little nod to Mark Williams for the unenlightened
318i Touring
This is what I have, was fitted in the green cabby:
http://www.db-audio.us/subwoofers/t-rex/t-rex-12/
My twin 12" has been built to go down to 5HZ
, but you'll never ever hear that.
37hz is where it's at if the female of the species is sitting in the car
TouringTash
I'm always suspicious of any speaker or brand who don't publish their specs alongside the speaker. Whats more important how it looks or how it sounds........
Then again in this day and age don't answer that.
318i Touring
feck that i had one and threw it away, sounded good but was too big. a couple of 8" ones so they fit under the roof compartment sound good for meRav335uk wrote:Alex, you want 2x12" in the boot
e30maddog
thanksTouringTash wrote:no door handle trim?e30maddog wrote:Focal K2 power for exampleAlex wrote:you sit in the front, surely you want decent speakers in there![]()
nice set up mind
ive been meaning to get a trim, i need to cut the lugs off and glue it on though, no other chice as the leather is too thick... and as for the fence... choice of playing with car or playing with fence.. car wins!!
Just bought these for the rear door cards:
Got these for the front door cards (scroll to the bottom):
http://www.audiosport.co.uk/bmw.htm
Should help with sound
e30maddog
nooo, 12''s all the way, 8's or 10's just cant cut what a 12 can do, i have both my 12's under the hood bit and they sound nice. i tried a jbl 15'' once.. got rid of it within a week and went bk to the 12's.Alex wrote:feck that i had one and threw it away, sounded good but was too big. a couple of 8" ones so they fit under the roof compartment sound good for meRav335uk wrote:Alex, you want 2x12" in the boot
My TS-w301 is Older than Alex.TouringTash wrote:I'm always suspicious of any speaker or brand who don't publish their specs alongside the speaker. Whats more important how it looks or how it sounds........
Not much to look at, but ithey're still going.
e30maddog
omg!! oldskool! well they say 'old speakers' are the best speakers ^^ i have a set of celestion 'ditton' house speakers from the 80's lol, but they are untouchable. even if they broke i wouldnt get rid lol
Did you pull that out of 1980's home stereo systemRav335uk wrote:My TS-w301 is Older than Alex.TouringTash wrote:I'm always suspicious of any speaker or brand who don't publish their specs alongside the speaker. Whats more important how it looks or how it sounds........
Maddog, you seemed shocked
I did say there were "Old"
These are run by a DAP600
Alex, I bought these in 1992
So there younger than me then. Just because i look 14 its no excuseRav335uk wrote:Maddog, you seemed shocked![]()
Ok, they look younger than you
Rav335uk wrote:Ok, they look younger than you
i was born in 1991
