Beemerlad's M52 Chromie
billgatese30
You better get it tested for the winter then
It'll be awesome in the snow
I'm ashamed to say I'm genuinely scared of it in the wet. I let my mate have a go in it last weekend and the roads were damp, I was bricking it in the passenger seat.
He's got a 328i and was impressed with the poke of the same lump in an E30.
2nd gear at 40mph and give it the beans and it lights the rears up no problem
billgatese30
It would be interesting to compare S50 and M50 side by side, as I know the S50 had no bother in lighting up the rears in 2nd and even 3rd in the wet
I used to love my 4 door in the wet
Couldnt abuse the chromie like though
Dezzy
- CR24v it's a lifestyle
I know what you mean Dan.I will be scared to give mine any right foot action in anything other than dry conditions.
I have decided thats what compacts were designed for
Got a silly little fault at the moment which has me scratching my head.
Seems to have a very slight misfire when only just touching the throttle. Last weekend when I drove the car last it did it a couple of times when pulling out of junctions in a sensible fashion, you could hear it was not running on all cylinders. Give it a bit more squirt and it catches and performs as normal.
Same situation when cruising on very light throttle, you get a bit of a jerk.
Any inspiration here guys?
I was thinking throttle position switch but don't want to randomly go through the engine bay replacing crap for the sake of it. The cam sensor is new and the crank sensor was replaced for a good working one.
toby
Test it with a multimeter and you don't have to change anything just to verify a fault with the throttle switch.
Check for slight air leaks too.
craigieeb
I was thinking about your crankcase breather pipe Lee,toby wrote: Check for slight air leaks too.
is it secure on the head side?
Uploaded with ImageShack.us
yes thats your engine bay
M50 Turbo!!!
I shall say no more
I'm pretty confident it is not an air leak problem as I was pretty anal when it came to re-fitting the inlet manifold after having the injectors cleaned. The crankcase breather pipe is a pretty snug fit.
It is defo not firing on all cylinders when you pull away.
Bloody MOT booked for tomorrow so will see what adventures come my way.
Dezzy
Good job I rang you then mate.
Have you spoke to Yoda about the symptoms?
Not spoken to Dan about it yet mate. Probably so many possibilities.
Dropped the car off for MOT this morning.
Damn thing started misfiring good n proper once it was warmed up. Sounded like a bloody impreza on occasions, so god knows how it will pass an emissions test.
Now why do I find myself looking at Audi S2 Avants on Pistonheads........
Dezzy
I have been looking at V8 XJR's
Well bugger me with a fish fork, It's passed the MOT
Dezzy
Well done Sir! Any inner rear arch flags raised?
No advisories at all mate.
It still misfired like a coont after I picked it up, so god knows how it passed. The garage I took it to belongs to a neighbour, but they don't actually do the test themselves, they take it to the local council testing station, so it must have behaved or they fell for the retro charms
Dezzy
Either way happy day I reckon. Now stop looking a poo audi's sort your mis fire and prep yourself for a cold one Sunday.
Dezzy
- Homo Hair
Don't be a wrong'un Lee..
Could they mount that lump any further forward...?!
When front springs/dampers and brakes become a regular jobJhonno wrote:Don't be a wrong'un Lee..
Dezzy
Wouldn't go near an E39 M5 mate
Dezzy
Do they have issues mate.
I really like them.
I really like them.
mcbunny
beemerlad haxby/wigginton by chance ?
- Homo Hair
Epic cars.. Bloody expensive to maintain properly.Dezzy wrote:Do they have issues mate.
I really like them.
Correctmcbunny wrote:beemerlad haxby/wigginton by chance ?
mcbunny
thought i recognised the house styles
i grew up in wigginton but out in pocklington now
in a few months i will be on the lookout for a nice 318iS would you be able to help in checking cars out as you seem to know them quite well ? obviously beer tokens are available for reimbursement of services etc
or just general local help would be nice just sold my 328 sport coupe last night s im now demoted to the mrs old micra for a while
Anyway your car looks great all the best
Mike
Mike
Dezzy
I am a low milage kind of guy. Not scared to maintain cars correctly. Plus have some trade connections. I may just have a look at a few after Xmas.
Mike, I'd be happy to take a look at some cars with you. Pop over if you fancy a natter, Wednesday & Friday nights I am usually free as well as Sundays. There's another zoner in Pock too called Scott, he's well versed with where E30's rust
Dezmondo - Uber Legend
Spoke with him tonight and he's sorting me with some coil packs to swap over. Thanks mate, PM on the way.
Drove the car home from work tonight and it is misfiring badly, sounds like a bloody scooby (cack). Hopefully it is a duff coil pack. I'm pretty certain it isn't anything like an air leak.
mcbunny
fantastic thank you !
will be in touch
will be in touch
beardymat
- Location: sheffield, city of steel, and rust apparently
Had a slight hesitation/missfire on the M3 too lee, would idle fine until it got hot then missfire and it would hesitate if you gave it a bootfull from part throttle, seem to have sorted it now though but ive fitted the correct five bar fuel pump, re shimmed the tappets and gapped the plugs correctly so not sure which one was causing the problems.
Also fitted a new pas pump to stop the whining but its as bad as ever so ive still got the hump with it, at a loss to that one, will have to start a thread if i cant find an answer soon.
My PAS pump is a bit noisy.
Going to check the vacum hose is still connected to the FPR too just incase it is something daft like that. Will check the plugs too of course.
Hope it is something daft as I lose patience with identifying electrical problems and there will be an Audi sat on the drive
Dezzy
No problem Lee. Glad to help
This afternoon after some mig weld splatter practice, I decided to fit the coils I got from Dez. Checked all the plugs whilst I was there, all plugs showing an even colour and gaps.
It has improved matters slightly, but the misfire is still there. I'm beginning to think this is more fuel related.
I can't vouch for the quality of the pump. Every time I put the ignition on, the pump is heard to prime for a few seconds. It fires up no dramas and ticks over without any dramas. The symptoms are that it splutters with an obvious misfire (sounds like an scooby) with light throttle open, if you give it a bit more beans it seems to clear and go OK.
I don't think it is giving full beans all the time. If you floor it then you get mixed results of sometimes it ripping your face off and sometimes a mediocre bit of performance.
Is it worth investigating the throttle position switch/sensor?
Should I look at swapping the fuel pump?
Any other nuggets of wisdom?
I'd not really driven the car for nearly 2 months and the brief test run it had made me smile, I gave it some beans once and it really felt bloody quick after driving a 16v Golf for the last 2 months.
