Right hola all!
First up whats the M20 engine weigh (I reckon about 230kg) anyone know for sure?
Second is it true you can use atlas diff plates in BMW diffs to make an lsd or re build and existing one?
M20 Engine weight and atlas LSD diff plates
M3Compact
Yes mate, it's a ZF LSD unit, as per all Atlas axles.Second is it true you can use atlas diff plates in BMW diffs to make an lsd or re build and existing one?
The only problem is that the Atlas uses 4 clutches and the BMW only two, so unless you machine the housing to take all 4, 2 are wasted and the Atlas kits are Ԛ£120.
Turbo-Brown
- Boost Junkie
There's no way an M20 weighs 230kg!
Me and my mate lifted my fully built 2.5 engine by hand with no trouble at all.
Mabey 130kg ish?
Mabey 130kg ish?
M3Compact
My guess is way more than 130Kg fully dressed, nearer 180Kg.
stappin
Well I was being on the 'safe side' you know add 10% for safety and allTurbo-Brown wrote:There's no way an M20 weighs 230kg!
Mabey 130kg ish?
Andy335Touring
- Homo Hair
me and a mate lifted a complete m20 out of the back of a vectra... so they cant weigh that much..
320Touring
sure it didnt just fall through the floor???Jhonno wrote:me and a mate lifted a complete m20 out of the back of a vectra... so they cant weigh that much..
think 130ish is right for an undressed lump
