hi car has just failed test on too much brake pedal trave.
have done the following which has made it a bit better,
new discs and new shoes at back.
was wondering how to adjust the pedal travel as a new servo was fitted a while ago. i understand how to do it its just last time i over did it and the brakes stuck on a bit so wanted to avoid doing that again( ie how much to adjust it by?)
cheers carl
brake pedal adjst.
i am pretty sure all of the above are ok, ye it can be adjusted i tried before with the help of a haynes manual and ended up with a sticking caliper( too much adjustment) just wondering how other people did them really
cheers carl
cheers carl
