E36 brake question...
Bristol_Jer
My mate from work has a 325 E36, and is wanting to upgrade the brakes. I don't really know anything about e36's, but I was thinking that E36 M3 brakes would be a good upgrade? Would this be right or are they the same brakes? Also would the e36 M3 evo brakes be better still? Thanks
nickso
- Location: Go do that voodoo that you do so welllllllll!!
might need to change the struts and trailing arms too though.
'88 e30 328i M52 track bint.
dips346
- London Meets Main Man
most go for the e46 330 upgrade
Bristol_Jer
Is the e46 upgrade a bolt on upgrade? Are there any forums I can let him know of that are good for e36's? Cheers
dips346
i think you just need to bend the back plate a bit but as long as you have the calipers and carriers it should bolt onBristol_Jer wrote:Is the e46 upgrade a bolt on upgrade? Are there any forums I can let him know of that are good for e36's? Cheers
forum wise
http://www.bmwowner.com/forum/index.php
Bristol_Jer
Nice one, thanks
dips346
nicked from another forum for the rear set up
330 rear bbk
heres the tired old set up
as you can see the 330 is massive compared
as you can see the lip on the otsid eedge of the backing plate will be in the way of the new dics so will have to be cut away, i used an air saw and munched it but i think the next best route would be a grinder as i can see it being an arse with a hack saw.
heres the next step
1, backing plate cat to suit
2, new shoes
3, all components dis-assembled wired down and copper greased
th erest is pretty straight forward just revers of the dis-assembly but with the new discs and calipers as they just bolt straight on
it now fills the wheel much better
[/quote]
330 rear bbk
heres the next step
2, new shoes
[/quote]
