swapping pointers
Gmont02
Post Mon Oct 25, 2010 11:18 am
looking to do the swap but im looking for any useful information on every little detail on the whole process.
for instance:
1:the rad position where would it be?
2:would it be a straight swap? just switch out the engine?
3:would the manual transmission be compatible? 325i cab compatible?
4:going to come back for questions lol etc,.
Ziggy
Post Mon Oct 25, 2010 11:35 am
Have a look at the guide at the top of the section :thumb:
http://www.e30zone.net/modules.php?name ... 93&start=0
leeparkes
Post Mon Oct 25, 2010 11:24 pm
Whats the E30 your starting with? 318-325i?
Gmont02
Post Tue Oct 26, 2010 1:00 am
87 325i cabby with over 200k
leeparkes
Post Tue Oct 26, 2010 2:41 pm
Perfect car to start with then, imo an M30 is just like a big M20 and it makes the swap a whole load easier.
You can use the 325i prop/linkages/rubber mounts/rad/exhaust/etc... the only custom thing you will need is the mounts *cough* see my sig :)
My build thread has plenty info with lots of pics
http://www.e30zone.net/modules.php?name ... c&t=129516
Ziggy
Post Tue Oct 26, 2010 2:51 pm
Mine should be pretty similar! But only if your car is red too.
http://www.e30zone.net/modules.php?name ... ic&t=72863
leeparkes
Post Tue Oct 26, 2010 8:20 pm
Gmont02 wrote:looking to do the swap but im looking for any useful information on every little detail on the whole process.
for instance:
1, rad will stay where it is
2, Virtually yes
3, you will need an M30 gearbox or there has been a thread about using an M10 box from a 316
http://www.e30zone.net/modules.php?name ... c&t=178307
4, yep you'll be back :D
staley_turbo
Post Tue Oct 26, 2010 8:26 pm
M30 FTW!
Gmont02
Post Tue Oct 26, 2010 9:24 pm
wow guys thx. ill post some pix as soon as i get started. great input :D
