Motronic upgrade - Vacuum hoses
clarko74
Post Sat Oct 23, 2010 3:23 pm
I'm in the process of upgrading my prefacelift 325 to Motronic 1.3 and have just changed the ICV to the T shaped one, this also involves changing the big AFM to TB hose as the the ICV enters this at a different place, this is my old hose:
The problem I have is that the new AFM to TB hose has not little hole for the vacuum hose at the back, here's how mine is looking at the moment:
I've had a look on the neb and found this pic:
Have I got the wrong hose, and I need to get one like the above one or is there another way around this?
Cheers,
clarko74
clarko74
Post Sat Oct 23, 2010 3:41 pm
I've just a search and found this:
http://www.e30zone.net/modules.php?name ... c&t=179635
Green wrote:That's how mine used to look in with the 320i engine in it, but when i swapped them over I only had one stubb for the vacuum hose so I blocked up the hole in the intake hose and then connected a the pipe to the stubb...
How it should've been fitted (see it's missing the stubb off the TB)
And how it is
Brakes are all working fine though so can't complain?
As I have two holes in the TB I'm assuming I can just run two hoses into the 2 into 1 piece and all will be well?
clarko74
charlE30
Post Sun Oct 24, 2010 9:34 am
I can't offer the answer to if it'll work (can't see why it wouldn't) but if it were me I'd either source the AFM-TB hose that fits your original twin pipe takeoff or find a L shaped ICV and use the orginal hose that you've already got.
BMW F31 335d xdrive
Post Sun Oct 24, 2010 10:06 am
The air hose you have found is for the last of the M20's, when the complicated multi connection valve for the brake servo was done away with. This is the hose I usually fit as a replacement to the earlier facelift M20's if needed, as it simplifies the engine bay and makes it much easier to dismantle the inlet side of things.
Take off all the excess stuff, block any unused holes, and connect the servo as in your last pic.
clarko74
Post Sun Oct 24, 2010 11:22 am
Nice one, thanks Brian.
clarko74
Post Sun Oct 24, 2010 11:59 am
its actually a manual/auto thing ady. the double pipe is fitted to the autos and the single to the manuals. You'll notice the servos are different as in the whole the pipe fits in the servo is the opposite side to the manual single pipe.
Post Sun Oct 24, 2010 2:50 pm
Simon13 wrote:its actually a manual/auto thing ady.
Not according to the ETK.
ETK shows a change in pipe, auto and manual from Jan '89 on.
DmcL
Post Sun Oct 24, 2010 6:16 pm
FYI u can cap off that hole. the brake booster will work just fine with it capped. mines laid out the same and i capped mine with no ill effects. also u could have kept the old ICV/rubber elbow as far as im aware. ive had both the T shaped ICV and the L shaped on mine and both worked as normal.
WMMotorsports
clarko74
Post Sun Oct 24, 2010 9:33 pm
Cheers for the replies.
I did wonder if the L shaped ICV would work, but I've got the new hose now and it's tidied up my engine bay a bit.
clarko74
e301988325i
Post Sun Feb 20, 2011 4:53 pm
I know this is going back a bit, but my manual early facelift has the complicated brake boster feed, I think it will be worth simplifying it.
I said:
e30topless said:
lock the wife in there
Ant
Retired Team Member
Retired Team Member
Post Sun Feb 20, 2011 5:01 pm
tap the plastic fitting M10x1mm and pop a nice allen head bolt in there with some threadlock.
safe, airtight and permanent
Post Sun Feb 20, 2011 5:13 pm
Can anyone suggest what this complicated servo feed was supposed to achieve, compared to the later single pipe and simple one way valve?
I've asked this question before more than once, and have never had a single suggestion.
e301988325i
Post Sun Feb 20, 2011 5:22 pm
There's 2 options I can see:
1) Atmospherically balanced, unlikely
2) More likely, a system to apply a constant vacuum to the servo even on the overrun which would produce higher vacuum levels.
I said:
PG325
Post Sun Feb 20, 2011 6:33 pm
Can I ask a question related to the servo pipe.
The single version pipe from the AFM to servo, where it enters the servo mine move slightly, should the pipe into the servo be tight?
PG325
Post Mon Feb 21, 2011 9:41 pm
PG325 wrote:Can I ask a question related to the servo pipe.
The single version pipe from the throttle body to servo, where it enters the servo mine moves slightly, should the pipe into the servo be tight?
Can anyone confirm re the above.
Post Wed Oct 19, 2011 7:16 pm
Better late than never!
The pipe into the servo is held in place by a rubber grommet. There is some flexibility in this grommet, and the pipe can be rotated, but it should be airtight.
Kedge
Post Fri Oct 21, 2011 1:33 pm
clarko74 wrote:Cheers for the replies.
I just stuck with the old ICV when i did the same swap and seem's to have worked fine.
Instagram - Kedge85
