1990 325i Cirrus Blue
Converted it from automatic to 5 spd
Next step was to sort out all the suspension:
totally rebuilt an ebay sourced E30 m3 5 lug set up with OEM BMW parts, added Bilstein B12 suspension kit, Turner rear upper shock mounts, AKG adjustable rear trailing arm bushings and weld in subframe & sway bar reinforcements, Powerflex rear subframe bushings, new halfshafts, guibo, rebuilt the E30 M3 brakes, added Turner SS brake lines. Did a tune up - fluids, spark plugs, cap and rotor, set the valve lash, new fuel pump, starter, fuel level sending unit, dash lights, fixed the rusty fuel breather hoses, replaced p/s reservoir and hoses.
Started some cosmetic work:
Alpina steering wheel, dead pedal, shift knob, hartge valve cover, E30 M3 Evo hood seals, euro rear plate filler, yellow fogs, Recaro SRD on Massive bracket, fire extinguisher...
Waiting for spring to mount my BBS RS 005/06 wheels and add sway bars/strut braces.
Here are some pics:
