Beemer325
Post
Wed Feb 09, 2005 9:22 am
Hey all
I've just recently bought new front and rear cross drilled discs and pads for my '90 325i. The mags on the car aren't standard (set of Smith's racing mags) and when I took the cover off to remove the wheel nuts, I noticed that there is a locking nut on there and I cannot get it off with the wheel spanner.
Would anyone have an idea where I could get one of these tools to remove it, or would I have to get the local tyre place to remove it? I would imagine they would need to cut it off and I'm worried about damage being done to the mags.
Simon
Post
Wed Feb 09, 2005 9:41 am
Go to your local tyre shop theyve got tools to remove them without doing any damage whatsoever!
Beemer325
Post
Wed Feb 09, 2005 10:27 am
Simon wrote:Go to your local tyre shop theyve got tools to remove them without doing any damage whatsoever!
Thanks for the advice Simon. I'll be going down there on Saturday. The guy from Kwik-Fit said that they would need to be broken off and that he didn't have the tool. Oh well.... don't go to Kwik-Fit again I guess.
Demlotcrew
Post
Wed Feb 09, 2005 1:07 pm
ITs hard to do with no key and almost all the time some kind of damage is done, if not to the alloy then to the baring.
Andrew
Simon
Post
Wed Feb 09, 2005 1:37 pm
Demlotcrew wrote:ITs hard to do with no key and almost all the time some kind of damage is done, if not to the alloy then to the baring.
Andrew
It took my friend about a minute to remove the ones on the touring, with no damage whatsoever not even to the locking nuts!
Demlotcrew
Post
Wed Feb 09, 2005 2:23 pm
You must have had cheap locking nuts. Mcguard ones took a pro 20min to take off from my car and the baring went straight after.
Andrew
Simon
Post
Wed Feb 09, 2005 3:01 pm
Demlotcrew wrote:You must have had cheap locking nuts. Mcguard ones took a pro 20min to take off from my car and the baring went straight after.
Andrew
Funny that..Mcguard ones they were! Didn't think they were that cheap!
Demlotcrew
Post
Wed Feb 09, 2005 3:04 pm
I dont see how your friend could remove them with no damage to the locking nuts.
Simon
Post
Wed Feb 09, 2005 3:15 pm
Demlotcrew wrote:I dont see how your friend could remove them with no damage to the locking nuts.
I saw! It was a large socket type tool, which he hammered onto the locking nut and proceeded to use a wheel wrench to undo it!
He gave me the locking nuts back afterwards and there was no damage to them at all.
Demlotcrew
Post
Wed Feb 09, 2005 4:49 pm
Well Mcguard boast about the fact that they have the best locking nuts and are very hard to get off with out the key. The guy who done one of mines did the same but he could not get the socket on at all. Are you sure they were Mcguard?
Andrew
Beemer325
Post
Wed Feb 09, 2005 5:03 pm
Demlotcrew wrote:Well Mcguard boast about the fact that they have the best locking nuts and are very hard to get off with out the key. The guy who done one of mines did the same but he could not get the socket on at all. Are you sure they were Mcguard?
Andrew
These locking nuts are rounded at the bottom and there are 2 grooves at the top when the tool would fit into. I really hope that the tyre place will be able to remove it as my brakes and discs are shot to hell and I need to replace them ASAP.
Simon
Post
Wed Feb 09, 2005 5:37 pm
Demlotcrew wrote: Are you sure they were Mcguard?
Andrew
Definiteley, I replaced them with exactly the same ones, I was shocked on how easy they came off!
calder
Post
Wed Feb 09, 2005 9:08 pm
you can buy the universal locking wheel nut removal set from, of all places, halfords.
Alternatively RS components do a nicer set if you have access to these at work.
Kind of misses the point of having locking wheel nuts really.
