M52 b30 stroker rebuild back on the road
Post Wed Oct 13, 2010 7:19 pm
your doing good here m8 8)
edit must be an e34 one, this donk is out of a 5er
Post Wed Oct 13, 2010 7:20 pm
magpie wrote:
erm,wtf is this?
This is a heater which plugs into the M50 air box. Throw it away. The hoses connect to the bottom of the throttle body and they can be removed. Have a look at the "M50 manifold onto M52" thread mate for pics of my inlet manifold and the plumbing going to the throttle body mate
and this :?
Connector for lambda sensor mate, I'd guess that engine was not running a lambda sensor, so won't have been running right (unless there is a lambda sensor in the exhaust manifold) - I would recommend you sort one mate. Speak to Steve (E30topless) as his was running without one and was gash until he sorted it.
what's the part on the left?
I think that is for the exhaust flap solenoid or to do with carbon canister crap, not needed as far as I know
Post Wed Oct 13, 2010 7:21 pm
Dan you homo :)
Looks like some crude as hell resistor.. The fan setup seems errrm. Interesting. I'd chuck the wiring away and start again.
Post Wed Oct 13, 2010 7:22 pm
E30BeemerLad wrote:Dan you homo :)
Post Wed Oct 13, 2010 7:23 pm
i'll see if it works and if not i'll see yoda for one of his :)
Post Wed Oct 13, 2010 7:47 pm
Mick, Dezzy has a non-vanos DanThe loom for sale (engine loom)
Otherwise speak with Yoda about a fan loom
Here is the pics etc for how the plumbing should be on the throttle body
http://www.e30zone.net/modules.php?name ... 12#1990612
Post Wed Oct 13, 2010 7:49 pm
Nasty!
This regulates coolant to heat the throttle body, fook it off son.
Make sure you fit a lambda in this!
You can chop it out, just make sure you insulate the Red/White wire if you dont remove all of it :wink:
Post Wed Oct 13, 2010 8:00 pm
cheers Dan :D
the car has no lambda?
is this what Dezzy done for topless steve?
that link will come in very handy Lee 8)
Dezzy
CR24v it's a lifestyle
Post Wed Oct 13, 2010 8:09 pm
Fook me, magpie you are bless!
How's things Dan?
I was going to reply but couldn't be arsed with sifting through the pics etc. :D
Post Wed Oct 13, 2010 8:26 pm
Dezzy wrote:Fook me, magpie you are bless!
How's things Dan?
can you sort this lambda jobby out Dezz,i know steves ran loads better after you'd sorted it :)
Dezzy
Post Wed Oct 13, 2010 8:35 pm
Yeh of course mate. You will need to get one though. E34 M50 lambdas are a better length. 8)
Cook318IS
Post Wed Oct 13, 2010 8:37 pm
i have a near as new bosch lambda from when i had my m50 in my e30 :wink: i think i only did something like 500 miles on it :?
Post Wed Oct 13, 2010 8:39 pm
so i buy a new one for e34?
or look at ebay one?? is the loom a separate part ???
looks like i have a list developing!
Post Wed Oct 13, 2010 8:41 pm
I've got one here mick you can have for nowt, only problem is the wiring has been bodged with terminal block, nothing 10 mins with a soldering iron wouldn't fix though.
Post Wed Oct 13, 2010 8:42 pm
E30BeemerLad wrote:I've got one here mick you can have for nowt, only problem is the wiring has been bodged with terminal block, nothing 10 mins with a soldering iron wouldn't fix though.
your a star mate :D
pm on way Dude 8)
Dezzy
Post Wed Oct 13, 2010 8:52 pm
I have one here Mick with no bodgy wiring mate from mine. I you can have that when we weld the boss in and fit it. The pic you posted with the plug in the clip at the bottom of the block (inlet side) is where it plugs in.
I will start a list here of the bits you want off me winkeye
Post Wed Oct 13, 2010 9:11 pm
ok dez don't forget the p/s pipes i need 8)
lee cancel that last pm m8,looks like wor dezza has the goods :D
aye champ :)
leeparkes
Post Wed Oct 13, 2010 10:36 pm
I dont think its a lightened flywheel Mick, the guy who originally done the conversion did a bit of sump shaving to make it fit.
http://www.e30zone.net/modules.php?name ... sc&start=0
Did you pm him?
Oh and, What is this?
Post Wed Oct 13, 2010 10:52 pm
leeparkes wrote:I dont think its a lightened flywheel Mick, the guy who originally done the conversion did a bit of sump shaving to make it fit.
Did you pm him?
Jhonno wrote: Looks like some crude as hell resistor.. The fan setup seems errrm. Interesting. I'd chuck the wiring away and start again.
Post Wed Oct 13, 2010 10:59 pm
Cook318IS wrote:i have a near as new bosch lambda from when i had my m50 in my e30 :wink: i think i only did something like 500 miles on it :?
just noticed this post,thanks for the offer m8.
i'll get the one from Dezzy as he has a few bits i need. :)
leeparkes
Post Wed Oct 13, 2010 11:07 pm
Yes but what is 'meant' to be on the end of that plug? :)
I agree with jhonno on the fan wiring, start from scratch bud 8)
Post Wed Oct 13, 2010 11:08 pm
did the fan kick in when you had it?
leeparkes
Post Wed Oct 13, 2010 11:21 pm
I didnt trust the relays so i hot wired it to a switch.
Dezzy
Post Thu Oct 14, 2010 7:06 am
No problem mate.
P steering pipes
Lambda boss and sensor and a bit of welding.
Out else you need?
Post Thu Oct 14, 2010 8:28 am
poss loom none vanos,does it have the leccy fan set up? i have a 3 pin sensor on the right of the rad.
Dezzy
Post Thu Oct 14, 2010 8:31 am
I have a loom and ecu here mate but the fan loom is a seperate loom. Danthe will make you one and it will be twin spead. Perfect plug a nd play option. just give him a pm :D
Post Thu Oct 14, 2010 8:36 am
Dezzy wrote:I have a loom and ecu here mate but the fan loom is a seperate loom. Danthe will make you one and it will be twin spead. Perfect plug a nd play option. just give him a pm :D
will do m8,
what part of the zaust shall i fetch over to you for the lambda job?
not sure if the rear fanimould needs further fettling for the e36 rack yet though :?
Post Thu Oct 14, 2010 8:45 am
Your better off getting it on the car before fitting the lambda TBH
Dezzy
Post Thu Oct 14, 2010 9:07 am
As yoda says get it in an running and drop down in the car mate. We will place it and have a look from there :D
Post Thu Oct 14, 2010 9:18 am
sounds good to me,i'll be down soon for the pipes and a l@@k your fan loom and ask a shit load of questions :mad:
Dezzy
Post Thu Oct 14, 2010 9:23 am
magpie wrote:sounds good to me,i'll be down soon m8 for the pipes and a l@@k your fan loom and ask a shit load of questions :mad:
Sound thats fine by me mate :D
wess
Post Thu Oct 14, 2010 5:31 pm
magpie i have pm'ed you about that loom i got of danthe
Post Thu Oct 14, 2010 8:56 pm
what diff is best to use for say 135mph ish and good m/way mpg in 5th?
i had a zoner round mine yesterday with am m52 and 3.46 diff and he limits out @ 125mph.
so the 3.64 i have will be no good to me :(
