Upgrading parts in an M50 swap
Duke137
Sat Oct 09, 2010 12:54 pm
Over the past couple of months I've collected nearly everything I need for my M50 swap. I just want to know, is there anything else I can change/upgrade to give it a few extra horse power and make it a bit more refined?
I have/will be doing the following:
M20 lightened flywheel
402 ECU (red label)
2.5" bore single pipe exhaust
My question is can I get the best out of the induction/inlet ? eg, what is the best air box/inlet etc etc?
I also plan on swapping the water pump (KWP) and M20 starter I have for brand new items.
I'm not going to go overboard with stuff (ie turbo/supercharger) I'm just after the little touches for behind the scenes.
Advice welcomed :D
Sat Oct 09, 2010 1:44 pm
Standard airbox with a brand new filter is all you need, cone filters loose you low end grunt.
Not sure if a single 2.5" exhaust system will do the goods or not compared to the usual twin setup.
If it's a non-vanos lump then a Speedtouch chip would quite possibly liven it up.
I would concentrate on just making sure that all vacum hoses etc are in tip top order so there are no issues
Duke137
Sat Oct 09, 2010 4:52 pm
It's vanos, I'll play about with the ECU's once its running I think.
The single pipe is probably the same as the chap who recently printed some impressive dyno results on here the other day, I can't find the thread but he is cooks mate?
I guess you mean standard M50 (E36) air box?
I know it's going to improve it no end anyway am just making sure.
Cook318IS
Sat Oct 09, 2010 5:00 pm
Duke137 wrote: I can't find the thread but he is cooks mate?
Sounds like monkey. Hes got a single 2.5" stainless exhaust on his and a few other mods and it made 217bhp
Duke137
Sat Oct 09, 2010 5:44 pm
Thats the one! thanks Cook :thumb:
monkey
Sat Oct 09, 2010 9:18 pm
single 2.5"exhaust works for me and makes a good noise :D cant say if it helps with power or not as i never tried a twin pipe set up but mine made good bhp . i don't know wot m50 e30s normally make though .
Sat Oct 09, 2010 10:13 pm
Yours has made the best power I've seen a stock M50 engine make with the help of just a remap/chip.
If it had those Schrick cams in Dezzy had for sale recently, phwoar I reckon it would be in the 230 region
monkey
Sat Oct 09, 2010 10:19 pm
i thought dezzy's cams where non vanos cams ?
Duke137
Sat Oct 09, 2010 10:44 pm
monkey wrote:i thought dezzy's cams where non vanos cams ?
They were non vanos
I like my single pipe system in makes a great noise on the M42 so it will be pornographic attached to an M50.
monkey
Sat Oct 09, 2010 10:56 pm
They were non vanos
i will sound good with 24v good luck with the swap
Duke137
Sat Oct 09, 2010 11:00 pm
monkey wrote:
They were non vanos
Cheers bud
monkey
Sun Oct 10, 2010 2:26 pm
E30BeemerLad wrote:Yours has made the best power I've seen a stock M50 engine make with the help of just a remap/chip
not so sure thats a good thing as in the past when i have owned fords they normally go better before they die .
