Complete novice bit now.
Where do i put it
many thanks
George
agree. Maybe lift pump dead?handpaper wrote:You should only start getting fuel starvation issues on looooong right handers with about 1/4 tank left. I'd suspect a contributory fault of some kind.
If you do fit one, pretty much anywhere outside the cabin - on the left chassis rail under the bonnet is a nice accessible spot.
Examine the lifter pump assy carfully. A fellow M3 owner has shown me pictures of his lifter pump with just the ground strap snapped of the carrier. Pump was fine after repairing this.George_Of_The_Jungle wrote:The cars is close to standard, and is for road use. I have only used it at the track once. I have been experiencing the fuel surge on the road but typically below 1/4 of a tank.
Cheers for all your input guys, I will look at getting a new pick up fuel pump first and see if that resolves the problem.
Many Thanks
George
This sounds like it could've been me?! Sorry if this is a cold thread but I've experimented with all sorts of solutions to this problem.agent006 wrote:I was talking to a fellow E30 driver at Colerne in June and he mentioned that he had the return fuel line terminated across to the other side of the tank. Something to do with it then being right by the fuel pump.
Does this make any sense? Was right at the end of the day so it's all a bit hazy.
