oil cooler
johnono
Post Sat Oct 01, 2005 1:11 am
wanted to know, i dont have a cooler on mine (320i tourer) but i fancy the idea,..
can, it be done, how hard is the conversion?
whats the pros and cons fellas, let rip :)
A1BMW325iSport
Post Sat Oct 01, 2005 1:59 am
i think you could fit the 325i oil filter housing, pipes and radiator and it should work fine
i have a 325 filter housing if you need one
Post Sat Oct 01, 2005 10:04 am
325 bits will all fit but I doubt if there will be much advantage. In fact I doubt if there's much need for one on a 325. Oils have come a long way since the mid 80's.
Dissadvantage is the potential for even more oil leaks - something the M20 does not need.
Templ8e30
Post Sat Oct 01, 2005 7:34 pm
I'm about to fit one to the 2.7, I got the filter adapter and cooler with the oil lines. I bought all the o-rings and mounting brackets/bushes etc fro the dealer for Ԛ£16. I already had the plastic grill for the front valance, if you haven't got one they are Ԛ£8 from the dealer.
The cooler was blocked with manky old oil when I got it so I flushed it through with diesel and left it overnight to soak. In the morning I flushed the diesel out and dried it with compressed air. No restrictions now :cool:
Will let you know how it goes :D
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Templ8e30
Post Wed Oct 12, 2005 5:46 pm
Oil cooler fitted and working fine. As it turns out the pre and post facelift models have different mountings on the cooler.
Fortunately the facelift cars have both sets of munting points on the car :D
Fitting only took about 45 mins, but you need a deep 24mm socket to get the stub adapter off the block to fit the take-off plate.
Cheers,
Iain T
GDBN
Post Wed Oct 12, 2005 6:28 pm
Hello matey .... I wouldn't bother with it .... I'd use the time and cash on something else as I don't think you will notice any difference !!!
Giles
Simon
Post Wed Oct 12, 2005 8:33 pm
As has been said, not really neccesary, not even on the 325i, more beneficial really for cars in warmer climates.
