6 speed ratios.
randomdave325
Random E30 Nutta
Post Sat Oct 01, 2005 8:51 am
hi ya. on the 6spd box a la m3 evo. is 6th 1 to 1 ratio? or is it higher. i'm really loving the acceleration of my low geared racer as can do nearly everything i've come up against from a standstill to a ton. but need another gear. without the same top end as that would be well annoying. also what sort of money do they go for?
The current fleet!
1990 318iS
1984 528ise
1987 325i sport
1990 325i cabrio
1987 m3 s50b30
'Turning money into noise' :)
Toby_Unna
Boost Junkie
Post Sat Oct 01, 2005 10:33 am
Dave my m30 was the same as that with the 3.91 diff, perfect gearing but just needed one more on top.
but i never needed to use 1st gear even when racing people off lights etc so i put a longer diff on and it's much better now. how many mph do you get in 1st and do you often use it? i guess i just have a bit more torque than you cos mine would be fine with a 45mph 1st gear (i used to have a 45mph 2nd with the 4.3 diff and it got great starts in that gear)
astondg
Post Sun Oct 02, 2005 1:25 am
I am fairly sure that 6th isn't 1:1 on the M3 gearbox. I think 5th is 1:1 and 6th is 0.83:1.
Aston
BMW E30 323i with some stuff
1:05.17 @ Queensland Raceway Sprint track
1:10.09 @ Queensland Raceway Clubman track
1:21.67 @ Morgan Park Raceway
ian332isport
Post Sun Oct 02, 2005 10:05 am
astondg wrote:I am fairly sure that 6th isn't 1:1 on the M3 gearbox. I think 5th is 1:1 and 6th is 0.83:1.
Aston
Correct.
M3Compact
Post Sun Oct 02, 2005 10:36 am
Don't disregard the weight, they're fooking heavy. :(
Also, mega difficult to strip and no parts available. :(
A mate of mine sold one for Ԛ£850 recently. (Exported to USA.) I've seen them cheaper tho'.
