S50b30 flywheel & clutch options
toadster987
Post Sun Sep 26, 2010 12:23 pm
Hi guys Im about to do a S50b30 conversion and wondered if anyone has used a lighter flywheel i.e M20 ? Im sure Iv read somewhere on here of this being done on M50 swaps with E30 M3 clutch and a modifing/pack up the clutch fork for release bearing. Sorry if this has been already covered but tried several searches with no success
Uploaded with ImageShack.us
ajay
Post Sun Sep 26, 2010 10:54 pm
i used the drift works light weight s50 flywheel and an uprated sachs clutch and preassure plate/release bearing combo.The engine spins up a lot better than it would with the standard dual mass flywheel but found the clutch very direct on/off,it takes a bit of getting used to and once the gearbox oil gets warm i got an annoying rattle, due to the flywheel being so light.It was great for a fast take off or sporty driving but i imagine hopeless manovering in a supermarket carpark! It gets my vote every time, im not sure about using the m20 stuff though.good luck
toadster987
Post Mon Sep 27, 2010 11:08 pm
Thanks for that ajay , Id like to bin the dual mass flywheel but without it being to harsh really
UweM3
Post Sat Oct 02, 2010 2:46 pm
TTV does a nice flywheel for S50
Dave_M3
Post Sun Oct 03, 2010 12:26 am
M20 clutch will last about 5 mins with an S50 anyway. Even the M52s can make a job of them easy enough with alot of abuse.
TTVs flywheel gets my vote!
Of course you could use one of these like I have for the back of my S54 winkeye
jaistanley
Post Wed Nov 10, 2010 1:37 pm
I have a JB racing aluminium flywheel that uses the M3 pressure plate and sprung M5 friction plate. It makes the engine a joy to drive with and feels exactly like a stock clutch... Not for big torque though.
Jai
e21Jason
Post Wed Nov 10, 2010 1:45 pm
Does anybody know if there is a sprung clutch palte that works with the driftworks or etc flywheel
Jason
BMW e21 track car supercharged s14 cage and fabrication by www.chizfab.com
Z3M Coupe for sale
69 Alfa spyder
Post Wed Nov 10, 2010 3:13 pm
I am running a Helix one
