hi, when i start my 325 up from cold it seems to be hunting for about 2-3 mins but once warmed up its fine, i've changed the blue temp sensor is there anything else i can do.
many thanks
						hunting on cold start
- Brianmoooore
Drive it would be one solution. Engines aren't designed to be idled for three minutes after start up.
It's probably hunting because of an incorrect mixture, usually weak, for one or a combination of several reasons.
Injectors long overdue for a service? Pattern 'blue' sensor' not 'tracking' resistance against temperature as intended, minor air leaks, etc.
