Is there any diference between the injectors from an M50 2.5
and the M52 2.8?
as i have a set for the 2.8 and the M50 inlet that came today had the injectors fitted,
so which are the ones to use??
(dunno if it means anything ....2.5 ones are green & the 2.8 ones are pink)
M50/M52 injectors
Use the pinkies dude. They will fit the M50 fuel rail. Or you can do what I have done and use the pinkies with the M52 fuel rail. You just need to us a small piece of plate to extend the mounting tab of the fuel rail onto the M50 inlet manifold (assuming you are using the M50 inlet mani)
craigieeb
of courseE30BeemerLad wrote: (assuming you are using the M50 inlet mani)
i'll just jab them in to the M50 fuel rail,
i dont have the 2.8 one for some strange reason
Cheers dude : )
M50 Turbo!!!
I shall say no more
