The Most Infamously Common E30 Fault
- Cypriotgeeza
hahaha Run just after you hear the scary laughter because the bombs about to go off!!skipunda wrote:OBC backlight
Or some sort of broken OBC. I thought for a moment I'd set mine to 'Predator' units?
[youtube][/youtube]
Check my M30 build threads:
- BEERBOY123
That's gotta be Harry's TV Highlight of the Week - 12 seconds video footage of a broken E30 OBC...
Two headblenders, couple of bags of MC Hammer, 5 litres of FFF, a 48ft bastard, a box of jumped-up custard and some soggy chimps
Worn drivers seat base and side bolster, and shiny steering wheel and gearknob due to the high miles on most.
but magically when they come up for sale they all seem to be just under 100k milesSpeedtouch wrote:Worn drivers seat base and side bolster, and shiny steering wheel and gearknob due to the high miles on most.
cheers,
harry
harry
I have only seen this system work once,Alex wrote:The biggest fault bar non is the hydrolic headlight adjusters not working.
Has anyone seen them work?
Hmmm lets see.
Intermittant wiper fault - check
water in footwells and boot - check
non existant inner arch - check
rear wheel bearing sounds like obi wans lightsaber - check
rust, rust and more rust- check
M10 auto choke headache - check
brake wear sensor always on - check
dash bulbs gone - check
bushes fooked - check
dodgy door locks - check
etc etc etc..........
But I still love her.
jaymos wrote: rear wheel bearing sounds like obi wans lightsaber - check
Barry, it was quite entertaining at first but after a year its become tedious.bss325i wrote::.:jaymos wrote: rear wheel bearing sounds like obi wans lightsaber - check
Went to look at a 316i the other day (1991 model):
-Central locking not working- check!
-Driver door window not working-check!
-Driver door mirror not adjusting-check!
-Heater not working-check!
-Driver & passenger seats knackered- check!
Goods points- NO RUST!
(except on sunroof, also mentioned earlier in thread!)
On the market for a E30 in white!
Thats bad considering the amount of e30s you have ownede30topless wrote:I have only seen this system work once,Alex wrote:The biggest fault bar non is the hydrolic headlight adjusters not working.
Headlight wiper motors seizing - I've had this on two of my chromey E30s, also an odd one of the windscreen washers one-way valves clogging and spraying water under the bonnet.
Also bad handbrakes on rear disc-brake models seems quite common due to rust and/or difficult adjustment.
TouringMatt
I actually have an fully working system that i brought years ago and have never, and probably will never get round to fitting, mainly because im fixing all the problems that have been listed so far in this thread!frogman wrote:You got there before me Alex!Alex wrote:Hydrolic Headlight adjusters never work
Has anyone here actually got a working system?
My own personnel top 3 are;
Cold speed idle,
Oil leaks,
and trying to work out if the noise is bearing/cv/diff/bearing or gearbox related
This time is rear bearing again
Matt
It's not the greatest i'll be honest. But where's the fun in that?Alex wrote:sounds like you got a shit cardanbear wrote:Lets just say the whole car is one big fault. There you go, everything covered
snakebrain
How do you sort the wiper motors?Speedtouch wrote:Headlight wiper motors seizing - I've had this on two of my chromey E30s, also an odd one of the windscreen washers one-way valves clogging and spraying water under the bonnet.
- BadMoonRising
Not heard of this one before. Although mine has just started coming on and off. Even though the tank is full. What is the cure?rimz wrote:washer fluid light.
If I had read this thread before I bought an E30. I may never have.
- Brianmoooore
This is probably the truest comment so far!Felix79 wrote:The previous owner is normally the biggest fault on an e30
Almost every fault mentioned so far is easily sorted, and if done properly, shouldn't occur again for another 15 years or so.
Washer light: Turn the switch the right way up.
Headlamp wipers: Seize in the output shafts. Dismantle, clean, grease, renew rubber seals at the front.
Central locking: Red/black wire mod; keep sill drains clear.
Disc brake handbrakes: Muppets adjusting cables at the lever, instead of adjusting in the hub.
To be fair, I owned four of them, two chromey 320i models and two facelift 325i models and they always kept going, despite over 100,000 miles on each. Not a single head gasket went, even though they all had the notorious earlier type hex-head bolts.
Pretty reliable overall, I'd say.
