E36 Compact Compact 328i ti M sport
leeparkes
Post Sun Sep 12, 2010 3:19 pm
Well ive had it under the car and its a fail, the box fits but one of the pipes is touching the driveshaft, its too high and the bend isnt tight enough to clear :(
Here
BUT ive had a torch shining through the tail pipes to see what direction they take, the peforated tubes go dead straight till about 3" from the end then curl up and out
This is the path it takes, perforated tubes go up to the red line then solid tubes go up and out
The plan is to chop 3" off the box then weld the pipes direct, ie get rid of the curls, i could chop the pipes off but the bend would have to be 'very' tight to clear,
here we go again :roll:
Not sure why its designed like this?
leeparkes
Post Sun Sep 12, 2010 10:35 pm
After searching i think ive found out what the backbox is.
E46 6 pot
This is a pic of a full Scorpion 325/328/330i system
looks very similar to what ive got
Andyboy
Alpina Colada
Post Mon Sep 13, 2010 9:21 am
Get it on Ebay, go back and get the Z3 system. You know that will fit. If you can get a complete Z3 2.8 system for around 200 quid, that's the cheapest you'll get it.
Post Mon Sep 13, 2010 12:23 pm
Andy is right, id rather start off with a box that fits properly, less work = more play :D
leeparkes
Post Mon Sep 13, 2010 6:04 pm
WTF was i on about yesterday cutting some of the box off etc... :mad:
Ive had it back under there today to double check whats what and all i need to do is cut the offending pipe down and weld it to the box
Needs to be cut here, i may need to shorten the other pipe a touch too to stop them hitting each other, simple stuff :D
You can just see the scratches in this pic where it was hitting.
I know what your saying about Z3 but If i went Z3 it will still need bodging on as the front section is too short, plus as you said id be £200 out of pocket, the Scorpion is staying :D
Just before i put the compact exhaust back on today i turned the Scorpion upside down and put it onto the end of the 328i centre section to see what it sounds like, i was expecting it to be loud and chavy but was very suprised, it gives a nice 'crackly' sound to it, not raspy or boomy at all!
Very happy 8)
BTW Andy the AFM turned up today, cheers buddy :thumb:
leeparkes
Post Tue Sep 14, 2010 7:36 pm
I set about chopping up the Scorpion today, 2.5inch off one pipe and 3.5 off the other, took some fettling to get the angles right but ive had it back under the car again and it clears with no issue's. :D
Ill let the pics talk :)
Then mocked up
Before
After
Ill take it to work tomorrow to get the old boy who makes my mounts to weld them on :D
Post Tue Sep 14, 2010 10:42 pm
If you get a move on you might be able to make santa pod :D
leeparkes
Post Tue Sep 14, 2010 10:53 pm
Im taking the e30 though it has crossed my mind :D
Post Tue Sep 14, 2010 10:59 pm
You know it will be quicker :D
leeparkes
Post Wed Sep 15, 2010 7:29 pm
Tut tut :nono:
leeparkes
Post Sat Sep 25, 2010 7:54 pm
Spent an hour in my friends custom exhaust shop today and rolled out with this fitted
The E46 Scorpion system 8)
It sounds fantastic at full chat :evil:
Dezzy
CR24v it's a lifestyle
Post Sat Sep 25, 2010 8:08 pm
Did you take any pics of underneath mate?
Which 46 system?
Any way of posting a vid of it running?
Questions over 8)
Post Sat Sep 25, 2010 8:18 pm
Looks good Lee :cool:
Get a vid up :twisted:
leeparkes
Post Sat Sep 25, 2010 10:31 pm
Ill get a vid up asap and a few shots from underneath
Dezzy, its off an E46 328i/330i 8)
Dezzy
Post Sun Sep 26, 2010 7:20 am
Nice one mate. A coupe not a compact?
leeparkes
Post Sun Sep 26, 2010 10:31 am
Off a coupe
Dezzy
Post Sun Sep 26, 2010 10:36 am
Cheers Lee :cool:
leeparkes
Post Sat Oct 02, 2010 7:26 pm
Dezzy wrote:Did you take any pics of underneath mate?
Here you go :D
Im going to change the clamps as they stick out like a sore thumb :o:
Here's a short vid of what it sounds like
[youtube][/youtube]
Dezzy
Post Sat Oct 02, 2010 7:50 pm
Doesn't that look like it was ment for the car. Nice looking job mate.
Not sure about the red diff cover but like your choice of diff bush. :D
leeparkes
Post Sat Oct 02, 2010 8:19 pm
I too am not sure about the red diff cover, it was one of my wild idea's :mad:
Post Mon Jan 10, 2011 7:26 pm
How's this going...? :D
leeparkes
Post Mon Jan 10, 2011 11:35 pm
Touch wood its been running fine :)
They do make a perfect daily driver, smooth powerfull engine in a light BMW hatchback 8) The 3.46 diff is fun round town but not so much on the motorway...
Im thinking of more power though now, i know of an S50'd Compact and its quite a weapon 8)
Post Tue Jan 11, 2011 12:03 am
On ebay recently...?
leeparkes
Post Tue Jan 11, 2011 12:12 am
No, i think i know the one your on about though, black was it?
The guy i know he's is blue and only looks like its worth £500, its a proper sleeper 8)
Dezzy
Post Tue Jan 11, 2011 7:53 am
leeparkes wrote:Touch wood its been running fine :)
My thoughts exactly! winkeye
Post Tue Jan 11, 2011 8:49 am
Anchors FTL, ally is where its at winkeye
Dezzy
Post Tue Jan 11, 2011 9:02 am
DanThe wrote:Anchors FTL, ally is where its at winkeye
I know exactly what your on about Mr The.
The best thing about S50 is i get to punt an M3 about for the winter :wink:
leeparkes
Post Tue Jan 11, 2011 11:13 pm
Do you know how much heavier the S50 is compared the the M52 (roughly). I remember you saying something about the head holds a lot of weight on them.
Post Wed Jan 12, 2011 10:14 am
They are bastard heavy lumps.. About 40kgs heavier, maybe a little less..
Dezzy
Post Wed Jan 12, 2011 10:28 am
Out for interest Johnno what wouyld the difference be between an M50 and an S50?
Well actually an Iron block M52B30 :wink:
Post Wed Jan 12, 2011 11:34 am
About 15kgs..
The S50 has a bigger head the the M5x lumps, so extra weight there.
To be fair though, my S50 was not a nose heavy pig by any means, but then it was hardly a boggo E30 chassis.. The weight will be less noticeable in an e36 due to engine position being further back relative to the front struts.
Dezzy
Post Wed Jan 12, 2011 11:38 am
iI would use M3 front legs etc as will so it should be fine shouldnt it :D
Post Wed Jan 12, 2011 11:50 am
Yes.. Front end is the same as the saloon. Obviously a little less arse weight though.
Post Wed Jan 12, 2011 12:15 pm
I reckon your about right with 40kg, its easily more than 30
leeparkes
Post Wed Jan 12, 2011 6:37 pm
I was guessing around 40kg.
iirc the iron block M50 is 22kg heavier than the M52 alloy block (presuming the S50 block is similar to M50) Then the extra weight of the head, then throttle bodies etc V's plastic manifold. It all adds up...
In the real world id say its not that noticable but then again my compact gained 20kg going from M44 to M52 so going M44 to S50 it will gain 60kg over the nose maybe more as im using the smaller M44 gearbox compared with the M52/S50 box.
You wont notice the extra weight Dezzy 8O
Have you considered an E46 Compact? i hear the S54 goes in with ease :)
