My M30 swap, few Q's
chu346
Mon Sep 20, 2010 9:27 pm
Hi, going to collect this tomorrow http://www.e30zone.net/modules.php?name ... highlight=
And would like to know how people go about the modding the gear shifter?
Also would my 320i pas pump fit the M30 engine?
Finally, what else will I need to do to fit the engine, different servo???
scottidog
Mon Sep 20, 2010 9:37 pm
Usually fits in position 2 with no fouling on the servo.
My m30's an auto but pretty much sure you have to use the m20 gear linkage.
No your m20 pas pump wont fit.
Best of luck, looks like a good setup you bought.
Scotty.
You win some, You loose alot!!!
chu346
Mon Sep 20, 2010 9:48 pm
M30B35 pump only then?
Tue Sep 21, 2010 11:45 am
Should look to fit it in position 3. Will be tight on servo clearance but should be enough space.
Will need an electric fan set-up.
Apart from that it should be plug & play i reckon
leeparkes
Tue Sep 21, 2010 7:17 pm
Use an M20 325i selector and linkage
320i pas pump wont fit
Standard servo and get it in pos 3
8)
zaust
Zone day release
Tue Sep 21, 2010 10:26 pm
I might have a pump for you, I can't go in P 3 as my inlet manifold won't clear the servo. It's a try and see thing. If you end up in p2 like me then the hunt for a mk 1 golf servo is a straight swap and that will allow the fit.
M30 Tech 1 Touring on gas.
town325i
Tue Sep 21, 2010 10:43 pm
Why use the mk1 golf servo though as the plastic wing'd clio servo is a much better choice
Tue Sep 21, 2010 10:51 pm
town325i wrote:Why use the mk1 golf servo though as the plastic wing'd clio servo is a much better choice
Because its an M30 conversion, ie not as good as it could be :wink:
leeparkes
Wed Sep 22, 2010 12:46 am
Pffft :D
chu346
Wed Sep 22, 2010 2:53 am
Can I not make the m20 pas pump fit? Surely someones done it.
Got an electric fan. How does that wire up?
Also, what engine mounts can I use?
Might have a go at fitting in a few hours time :)
charlE30
Wed Sep 22, 2010 8:19 am
You'll need the custom mounts that Lee sells or from www.e30.de and standard M20 rubber mounts.
I'm in P3 with the seam removed off the inlet manifold and standard E30 servo but it's a little tight. I would fit the clio servo as about, it'll give more room for doing the plumbing.
Electric fan can either be wired in correctly using a two position temp sensor in the rad and hard wired into the fuse box or as some have done just wire it up to a relay and switch.... the only time you really need a fan is when stationary..
Ignore the PM I sent you as this thread has answered it :cool:
BMW F31 335d xdrive
stbaz
Wed Sep 22, 2010 6:50 pm
chu346 wrote:Can I not make the m20 pas pump fit? Surely someones done it.
the mounts were attached to the engine when you collected it chu
chu346
Wed Sep 22, 2010 9:54 pm
Well it was a long round trip, 780 miles, 2pm till 4am.
Nice to meet you baz, you've got some nice projects on the go. Can you tell me how the fan you gave me attaches?
I wanted to know what rubber mounts work with the M30 motor mounts?
Tried to install the engine today but couldn't get it sitting on the mounts. I could do with removing the gearbox and a better engine lift. I got the engine a gearbox in together, but couldn't get it in position, it wouldn't go back far enough. Gonna give the bulk head a good bashing at the weekend.
What do you M30 guys have for:
Suspension
Brakes + wheels
stbaz
Wed Sep 22, 2010 10:41 pm
just had small brakets and bolts holding fan into front panel, rubber mount wise I'm sure it's e28 535/m5 rubbers
brakes at the moment are 325
suspension is e36 alpina rear springs with e30 gaz adjustable shocks
e30 spax adjustable front inserts and jamex coilover springs and spring seats
all mix match but works well together on my car
leeparkes
Wed Sep 22, 2010 11:20 pm
Ive used M20 mounts and are plenty strong enough, to get it in pos 3 you need to remove the engine mount off the block on the exhaust side otherwise you wont clear the servo.
Lift the engine onto the rubber mount on the inlet side in pos 3, then refit the exhaust side mount when in position.
Im using Apex 40mm springs with Boge turbo shocks, it could be better but its passable. im on standard 325i brakes which for a road car do the job fine.
do you have any plans for this? ie turbo :D
780 mile trip 8O
Wed Sep 22, 2010 11:30 pm
Make sure you have the metal cups that go underneath the M20 engine mounts, helps keep them in place.
chu346
Thu Sep 23, 2010 4:48 am
That sounds like it could work Lee, I'll give that ago.
What are these "cups" and where do you get them from?
Hope to go turbo about this time next year :D
zaust
Zone day release
Thu Sep 23, 2010 8:28 am
I'd never seen the cup's till sunday on rav's car. Think it's a cab thing. I don't use them and had no issues.
Thu Sep 23, 2010 8:32 am
Thu Sep 23, 2010 8:53 am
zaust wrote:I'd never seen the cup's till sunday on rav's car. Think it's a cab thing. I don't use them and had no issues.
It helps stop them "Flexing" so much, and might help over come the problem of the Manifold hitting the servo like yours does in pos 3 Marc.
Ziggy
Thu Sep 23, 2010 9:29 am
Have a read of the sticky at the top of the section Chu! :)
zaust
Zone day release
Thu Sep 23, 2010 12:13 pm
It will only raise the height a mil or so, Won't make any difference to the servo clearance. I tried the e28 m5 mounts to see if the height made a difference already, but no it did not.
chu346
Sat Sep 25, 2010 9:16 pm
Afew pics
M20B20 now gone :woohoo:
M30 waiting
engine and gearbox going in together, with a 50 yr old crane
Just need to adjust the lenghthen the prop. Fit the fan and radiator. Fit the exhaust and find an airbox.
Does anyone know the prop adjusting nut size?
Also the fan that came with the M30 is the same size but thicker than the M20B20 one, and because of this it doesn't fit as it touches the engine. Plus I need to get the T piece and heater pipes.
That worked well for me Lee, thanks.
Sat Sep 25, 2010 9:21 pm
Chu, you forgot to cut the front pully off, thin will touch the rad, get a grinder, cut it along the "V" and it drops off.
shedrool83
Sat Sep 25, 2010 9:28 pm
The fan will need to be fitted in front of the rad.There is no room to fit a fan between the rad and the engine.
chu346
Sat Sep 25, 2010 9:34 pm
Thats the way I bought it.
This kit has been in two cars so it shouldn't be a problem. Doesn't the PAS pump go on that pulley?
chu346
Sat Sep 25, 2010 9:35 pm
shedrool83 wrote:The fan will need to be fitted in front of the rad.There is no room to fit a fan between the rad and the engine.
I know, got an electric one thanks.
stbaz
Sat Sep 25, 2010 9:36 pm
Rav335uk wrote:Chu, you forgot to cut the front pully off, thin will touch the rad, get a grinder, cut it along the "V" and it drops off.
this engine is the very one out of my car and is a was removed...... There was no pulley touching radiators in my car so why would it in his?? There was at least 40mm between them!!
chu346
Sat Sep 25, 2010 9:45 pm
What is this little black pipe, that comes off the vacuum valve thingy? Should it be connected to anything?
Sat Sep 25, 2010 9:52 pm
It just looked like it was still on, if it's off, that's ok, just helping out. 8)
gareth
Sun Sep 26, 2010 12:05 am
chu346 wrote:What is this little black pipe, that comes off the vacuum valve thingy? Should it be connected to anything?
That should have a little rubber cap on it. It goes nowhere.
chu346
Sun Oct 10, 2010 6:14 am
My radiator doesn't fit. I think it's from a facelift 325i, but after a struggle to get it in position, the dizzy is touching it. I can fit my 320i radiator but I'm sure that won't be uptoe the job.
What options do I have?
E28 535 will have to buy new.
E34 535 will be about as thick as the 325i rad but easier to get 2nd hand?
320i rad won't be upto the job?
Sun Oct 10, 2010 11:04 am
Either will do, Leeparkes ran his M30 with a M20 325 rad for ages with no probs, I have an E34 rad, no probs either.
chu346
Sun Oct 10, 2010 11:25 am
What I'm saying is that the 325i rad don't fit. :(
stbaz
Sun Oct 10, 2010 11:30 am
as i said when you pm'd me with all the complaints about this "full conversion" i sold you.... the radiator you got is the one out of my car. EVERYTHING you got came out of my car and ran / drove perfectly . as i said i have the m60 radiator in my car now so there is no way you were giving anything other than what was in my touring. there should be no reason that this doesnt fit / that doesnt fit.
ive not heard from you regarding the spark problem either ? i presume you have the engine sparking now?
