325ix dics
player6
Post Thu Sep 29, 2005 5:03 pm
will 325ix rear dics fit on a 325i
scot 328i with 260bhp
Simon
Post Thu Sep 29, 2005 6:47 pm
I would imagine you would need to get the 325ix calipers as well, due to the ix rear discs being vented rather than solid, so being thicker, it would all be a straight swop otherwise.
player6
Post Thu Sep 29, 2005 6:52 pm
i am going to fit 4pot calipers to them i wanted to no if the dics go no
Simon
Post Thu Sep 29, 2005 6:55 pm
Ah OK, I've just checked the ETK, and the drive flanges between 325i and 325ix are different, quite what the differences are I'm not sure.
M3Compact
Post Thu Sep 29, 2005 8:58 pm
:eek: 8)
Thanks Simon. :wink: 8)
Demlotcrew
Post Thu Sep 29, 2005 9:01 pm
IX has a different offset, so it will not fit! (unless you have the arms as well, you could get anal and say you only need the hub, but for simplicity we go for arms as a whole)
Player where did you get your K-macs from? Bexleys fitted it?
Andrew
Simon
Post Thu Sep 29, 2005 9:05 pm
:eek: 8)
You have plans now then!? winkeye
M3Compact
Demlotcrew wrote:IX has a different offset, so it will not fit! (unless you have the arms as well, you could get anal and say you only need the hub, but for simplicity we go for arms as a whole)
Andrew
Do you know if it's more offset? 8)
According to the ETK, it's only the Touring that has vents, but mine only lists LHD anyway :oops: , so could be wrong.
Demlotcrew
Post Thu Sep 29, 2005 9:07 pm
Yes only touring! dude the hub sticks out more! so does that mean its a larger offset on the wheels? i get confused with offset all the time.
I would not bother really ive yet to fade the rears!
Andrew
player6
Post Thu Sep 29, 2005 9:09 pm
i got them from bexley thay fitted them to
M3Compact
Post Thu Sep 29, 2005 9:11 pm
Possibly, the Z3M and M Coupe rear vented discs are a problem for me to use, I've been wandering around car parks sticking a tape measure through the rear wheels of BMWs with rear vents. :mad:
Demlotcrew
Post Thu Sep 29, 2005 9:12 pm
player6 wrote:i got them from bexley thay fitted them to
Okay dude how much did it lower the car by? and the costs? are they supper bone shattering hard?
Andrew
player6
Post Thu Sep 29, 2005 9:16 pm
thay lowered it by about 15-20mm dont no how much thay cost
M3Compact
Post Thu Sep 29, 2005 9:17 pm
More offset. 8) (From the centre of the disc.)
Bo11ox. :oops:
Just realised. :oops:
They'll be 4 stud. :oops:
Demlotcrew
Post Thu Sep 29, 2005 9:19 pm
20mm :x
Thats too much! might have to get a CNC spacer made up then.
Boloxs!
Yeah four stud. :cry:
Andrew
player6
Post Thu Sep 29, 2005 9:23 pm
i had 80mm spring on the front befor i had them fitted and after thay fitted them the wheel was rite under the wing so i had 60mm spring put on
Simon
Post Thu Sep 29, 2005 9:26 pm
Have you spoke to Ian Godney? He's the man to talk to about all things brakes!
http://www.godspeedbrakes.co.uk/
