In the middle of doing my conversion. What servo and master cylinder do I need to go behind the head lamps
baz
loom help and What servo and master cylinder?
stbaz
also need some loom help. im using a 1993 e34 530i loom.
the loom has the wiring where the two lambda sensor plug in, at that point there is also a two pin plug. what is that for?? its pictured on e30.de but it tells you in german and translator dont make sense.
there is also the obvious where it goes into the car i.e ecu plug, battery voltage and negative feeds and the three realysbut then there are these plugs pictured below....what are they and do i need them ??
baz
baz
stbaz
so i need to use the first two plugs shown?
stbaz
looking at e30.de there is a picture of the loom layed out and it says what the plugs are. the second on i have pictures seems to be white apose to black and is for abs/asc
however the first one pictured... x10104 is not shown on the e30.de loom picture.
stbaz
WILLNZ, i have since spoke to a very very helpful german.... non of these plugs are needed / used on an e30 conversion
RESULT!!!!
RESULT!!!!
glenn
- Engine Transplant Services
i used the hydraulic booster set-up from a 750i on my conversion
Driftben
i have a mk1 golf brake booster forsale which is a perfect size for there and the E30 master cylinder fits straight on it.
iv gone for the pedal box option...... easier but darn expensive
6pot wilwoods front
4pot Porsche rear
89 E30 stripped running a 6speed V8
Twin Turbo M60 in progress
FormerMember
You don't need to use them, all you need is in the big X20 connector. Reverse-signal comes through one of them, though. Here you can see the pinouts: http://users.tkk.fi/jhaukile/ETC/C101_X20.pdf
Brake booster; easiest is to use one from E34 V8, it has all the linkages which are suitable with some modification.
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
stbaz
i did some hunting about and ive ended up with ...vw all the same....passat tdi 9inch servo and 22mm master cylinder. pics to come soonSTiBen wrote:i have a mk1 golf brake booster forsale which is a perfect size for there and the E30 master cylinder fits straight on it.
