What cars do large flange props come from?
appletree
I'm after a Prop to fit my 6 speed m3 evo box, i know i need the large flange type like the evo or 328 has but is there any other car that uses the same type as i only need to chop the flange off and weld it to my shorted IS one.
craigieeb
Can you not just swap the output flange over?
so take the one off the evo, box and fit a different one?
like it's done on the M30 conversion??
M50 Turbo!!!
I shall say no more
penton08
all the v8 engined cars ive seen have the larger flange, m30 engined cars have them too i think! fairly sure e39's do to.
vokietis
324td
appletree
I'm after the cheapest option so somthing like a e34 530 auto would be a nice cheap undesirable prop, if it fitted
FormerMember
E30 M3
E30 325e (before '87)
E30 324td (maybe 324d also)
E36 328
E36 M3
These all are straight bolt on with 5 speed boxes, though i'd guess you had to shorten them with 6 speeder.
E28 M30 powered(?)
E34 M30 powered(?)
E32 M30 powered(?)
... those might also fit?
If you mean the "medium" sized flange. V8 and V12 have even bigger flanges..
E36 328
E36 M3
E28 M30 powered(?)
E34 M30 powered(?)
E32 M30 powered(?)
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
