front coil over information
town325i
Not really there are a few people on here who have done this and made there own coilovers oldersroy i think his name is has done thism_jermyn wrote:Why reinvent the wheel?
Buy a reputable brand its so much safer for all of us..
Rally designs do parts to make coilovers for escorts and I'm sure I've heard people using them with E30 struts - http://www.rallydesign.co.uk/index.php?cPath=1358e
Quite a few people have made their own - not really that difficult.
BMW E30 344i track car
BMW F31 335d xdrive
BMW F31 335d xdrive
- E30 Zone Meets/Events Team
- Contact:
I have these, ordered ages ago and still not done anything with them.
http://www.rallydesign.co.uk/product_in ... ts_id=3450
HairyScreech
why bother at the back, get it set to the height you want and use the fronts to get the desired rake.
afterall coilovers are not for slamming you car to the floor, there designed to allow you to adjust the weight over each wheel to enable you to get the required rake and wedge on the chassis.
the other advantage is the standardised smaller diameter spring, something which is of no advantage on the rear of an e30.
also i question if the rear damper mount top AND BOTTOM can take the abuse in the long term on a road car.
personally i wouldnt want to risk it.
town325i
If thats aimed at me it would be usfull to have the height adjustable because i actually use my touring to carry things its not to ponce about in and some time when i have a bit of weight in the boot it would be nice to be able to heigher the rear end a bit. I found coilovers very usefull on my mk2 golf when it had an M50 engine in the boot!HairyScreech wrote:why bother at the back, get it set to the height you want and use the fronts to get the desired rake.
HairyScreech
it was just in general bud.
i know what you mean about weight in the back, having had an essex v6 in my boot.
is it possible to fit the caravan towing spacers to a beehive spring? if so thats a nice cheep solution.
HairyScreech
yep thats the kiddys, should actually be easier to fit and then remove than rusty coil over threads after 1 winter here.
- Contact:
Faulkner springs will make any spring rate, size and height you want.
http://www.dfaulknersprings.com/
