I have done some research but still need more help.
The sub i have is a Vibe Space 12; 1000w rms.
The amp i have is a Vibe black box bass 1; 650rms @ 4 ohm, 1000w rms @ 2 ohm, or 1250w rms @ 1 ohm.
The trouble i think i will have is getting the bass through the double wall, any advice on how to overcome this? Boot space is no issue, i never use the boot in the e30's and neither is the amount of work required.
Some ideas i've seen/read on revlimited:
"building a single 10 inch sealed box, with a high output subwoofer like a type x, or solobaric. biulding it as low and narrow as possible ( say 11 x 11 ) maybe .8ft2 . wall on the trunk gets cut 11 x 11. box gets pushed through that hole onto the cabin wall, where the cabin wall will have a 10 inch round hole cut. Box will be sealed against the cabin wall. Output would come straight through the seat. how would this work?
OR
