which diff ?
k20trew
Thu Jul 29, 2010 11:09 pm
dropping a m30 in over the winter
and was wondering your opinions on which diff ratio is
best suited to the m30 ?
[drift intentions apply] :)
vokietis
Thu Jul 29, 2010 11:11 pm
3.46 for driftin 3.15 for normal use IMO
Thu Jul 29, 2010 11:14 pm
Nope, you'll need a 3.73 or 3.91 for Drifting.
3.46 for nrmal road use, I have on fitted on my M30.
Also, what gearbox will you be using?
3.15 is too low for the M30 in the E30
k20trew
Thu Jul 29, 2010 11:22 pm
thanks guys
rav i will be using a e28 manual box :D
leeparkes
Thu Jul 29, 2010 11:51 pm
3.64 is a nice ratio, 75 mph @ 3k and enough balls to spin the rears all over the shop :D
Im running a 3.73 which gives me 72mph @ 3k and its very lively through the gears.
Fri Jul 30, 2010 7:56 am
Is 1st still usable with the 3.73??
charlE30
Fri Jul 30, 2010 8:29 am
3.07 on mine, the M30 has plenty of torque to cope with it from low down, if anything it makes the lower gears much more usable. Hits 60 in second with ease and rather rapidly
3.91 also been on mine, 1st gear is useless and crap if you do any commuting but damn good fun for getting the back end out
My life has become one long commute so the 3.07 is 85 @ 3k
BMW F31 335d xdrive
Fri Jul 30, 2010 11:35 am
I've got a 2.93 going in mine.
For drifting you will want a taller/higher diff.
DonkeyPunch
Fri Jul 30, 2010 10:00 pm
I have a 2.93lsd also, and it's pretty good for a daily.
Good mileage, you can cruise at high speed, and Less shifting.
leeparkes
Sat Jul 31, 2010 6:38 pm
Rav335uk wrote:Is 1st still usable with the 3.73??
Just about :D
k20trew
Mon Aug 02, 2010 10:25 pm
i think the 3.73 is for me thanks lads
johnl320
Tue Aug 03, 2010 10:35 pm
3.07 on mine, makes 1st usable :D
S38B38
Sun Aug 22, 2010 7:12 pm
I am running 3.73---- w/S38B38 and 245-35 17" and the ratio is to short IMO,, i am going to 3.46
and i have plenty of power
Sveinbjörn Hrafnsson
E30 CABRIO M70B50 V12 5lug
ALPINA B10 BITURBO 346@507
550 V12 JML Motorsport
MrGMan
Thu Sep 09, 2010 8:43 pm
so the way i see it 3.91 is the best to have some in the first gear to swing the back out ?
Pembo
Sat Sep 11, 2010 5:55 pm
I have a 3.91 and the wheels just spin in first! Been great fun as I use the car from drifting but I find you seen forever changing gear. Im going with a 3.63 meduim case. So somewhere in between everyone elses recommendations.
Sat Sep 11, 2010 6:01 pm
3.64 or 3.73
Jeltuh
Tue Nov 09, 2010 3:19 pm
Just use a 3.07/3.25 lsd from a E28. Or for drifting a 3.64
