I swapped out my old cracked dash, and also put in a new centre console. I tidied up all the wiring and removed several feet of old Nokia, Motorolla, Ericson etc cabling. The old one had, had so many handsfree kits screwed into it, it looked like someone had taken a 12 bore to it!
I also splashed out on some new heavy duty mats. Its really given the interior a lift, and there are no rattles either!
I also spent a day in the engine bay. I'd bought a rocker cover at Gaydon, and had painted it in heat proof satin black paint. After it had cured, i carefully sanded back the raised bits and gave them a polish with some Autosol. For good measure i also gave the intake manifold a lick of paint. I topped it all off with a load of new bolts. I was gobsmaked at the difference it made. Cost around £25 to do with a few gaskets, bolts, heavy duty degreaser and a tin of paint. (i used Plastikote grill paint by the way
I was so pleased, i gave it a wash and took some piccies in the afternoon sun
Back to work tomorrow
Just as well though because my hands are cut and bleeding, and i need some healing time!
