Spark Plugs for M20
Jack-J
Fri Aug 27, 2010 12:37 pm
Hi all,
I have a BMW E30 320i and has started doing a bit of drifting. What are the best spark plugs for this engine?
Regards
Jack
town325i
Fri Aug 27, 2010 5:29 pm
ngk's are the best plugs you can use these engines dont run right on the fancy multi electrode plugs
silversideofthemoon
Fri Aug 27, 2010 5:42 pm
ngk in mine all me local garage sells
formally touringandy.............driving e30 320i touring and e39 535i
HJG-E30
Fri Aug 27, 2010 6:16 pm
Guy before me put some fancy 4 point Bosch ones in. If I replace these with NGK will i see a noticable difference in performance?
silversideofthemoon
Fri Aug 27, 2010 8:15 pm
unsure i always used champion as it was stated somewhere i read ....just use ngk now and there bout 2 quid of mme mate in his place each
town325i
Fri Aug 27, 2010 9:21 pm
HJG-E30 wrote:Guy before me put some fancy 4 point Bosch ones in. If I replace these with NGK will i see a noticable difference in performance?
You will notice a difference ove those things i used a set for a few months in my 325i and i had all sorts of problems cause by those plugs.
Switched back to the ngk's and the car ran fine
Fri Aug 27, 2010 9:25 pm
NGK BPR6ES , the best M20 plugs :D
