Check lights
Hi wondering if anyone could help iv got my self a 320 when sometimes I start the car my check lights come on for the rear and licence plate and brake light when I check my lights at the back there all fine,this only happens sometimes but all lights are fine and lights work but sometimes check lights stay on any idears?
town325i
well the brake check light will come on untill you push the brake pedal and the number plate light you will more than likely have a dodgy connection on one of the bulbs remove it and clean up the connections
Yh I get what your saying about the brake pedal once I do press that the brake light goes out,and when I start driving the licence And rear brake check comes on,iv pulled the rear light trays out and cleaned the connection points,it's a real strange one as it happens now and then,anyfink else I shoud clean up?
silversideofthemoon
this is the same in my 320 all bulbs replaced contact cleaned the whole board still i get this reading intermitent fault me seems
formally touringandy.............driving e30 320i touring and e39 535i
It happens to mine but only at night, spooky...
- Longman325Touring
It could be a problem with the check control relay; This is tucked up above the L/H rear wheel arch.
I had a similar problem on the touring, in that all the rear check lights came on one day, spent ages cleaning connections on bulbs etc, only to later check the relay and notice that I had pulled one of the connector plugs out!
- **BANNED**
Brake light check LED will always come on with ign,goes out when the footbrake is used first time,if it stays on,you have a fault.
Usual issues with these things are voltage related,the sensors are very sensitive to voltage change,a poor quality bulb is enough to convince the sensor that the thing is not working properly,at work,there is a similar system on our Mercedes trucks,we have discovered that the 'bulb out' message will appear if the wrong wattage bulb has been fitted to a rear light unit.....
Corrosion is the usual fault with the numberplate light,I had a car that would light the license plate LED just by going over a ridge in the road....
Youth is wasted on the young.
silversideofthemoon
will check bulb wattage cheers daimler
Something that annoys me.... every now and again my "Rear lights" bulb will illuminate. I go to the back of the car and sure enough one isn't working, and it's a simple case of the connection coming loose, so I re secure it and the tail light comes back on. However, the check control light remains on until i restart the engine; is this normal ??
