Wilwood 4 pots - which pads
LondonTom
Post Tue Aug 24, 2010 7:34 pm
Any recomendations would be appreciated, it's a track car, but is driven to and from circuits.
Tom
rix313
Post Tue Aug 24, 2010 8:31 pm
I've only had experience with Wilwood's own pad on track but the car hauls up pretty well, got no complaints. I've just bought some EBC yellow stuff pads for it which I'm hoping to test out very soon at the next track day so will let you know!
agent006
Post Tue Aug 24, 2010 10:05 pm
I have redstuff in my WMS 4 pots and have no complaints at all on road or track.
tomislav
Post Tue Aug 24, 2010 10:10 pm
I have wilwood's newly developed pads in the front of my car with 4 pots.
Rally design supplied them (they're the sole official uk importer of wilwoodstuff so best to use them!) after them coming out early this year.
I've done 15 laps of the ring on them and they are truly awesome.
About 45quid a set,
LondonTom
Post Tue Aug 24, 2010 10:39 pm
Cheers Guys.
tomislav wrote:I have wilwood's newly developed pads in the front of my car with 4 pots.
About 45quid a set,
Thanks mate - which model caliper do you run?
tomislav
Post Tue Aug 24, 2010 10:54 pm
Err, to of my head i cant remember.
Its a 310mm disc, with 4 pot caliper, black in colour.
Minilite, supalite maybe?
I'll try and find out.
Think its a midilite
LondonTom
Post Tue Aug 24, 2010 11:09 pm
Cheers dude.
e301988325i
Post Wed Aug 25, 2010 8:55 pm
I use wilwoods own and they're great apart form the squealing, keri-WMS recommended trying redstuff to reduce the squeak! midlite - 280mm solid G60 discs
I said:
e30topless said:
lock the wife in there
Theo
Post Wed Aug 25, 2010 9:38 pm
I use EBC yellows which work pretty well. I tried Ferodo DS2500s which worked quite nicely but only lasted one and a half trackdays.
LondonTom
Post Wed Aug 25, 2010 10:04 pm
Thanks guys - I'm not actually sure which model calipers I've got yet - bought the car with them on.
I certainly know what you mean about the squeaking!! I've heard similar feedback about the DS2500's and the DS3000's are a bit pricey for what I want to be paying.
Cheers again.
tomislav
Post Wed Aug 25, 2010 11:21 pm
Big brakes with racing in mind always sqeuak. You wanna here the farrari's and porsches when they're just normal driving, let alone after a track day, they squeal like a banshee lol.
duracel79
Post Thu Aug 26, 2010 1:05 pm
I've used the wilwood poly 'A' pad and although they work well I'd never use them again.
Very agressive dust which eats into the wheel powder coating. Later found they destroyed the front discs very quickly through wear. the dust was probably hot metal from the discs :-x
Now gone back to EBC yellows with a new set of discs.
Duracel79
LondonTom
Post Thu Aug 26, 2010 2:17 pm
duracel79 wrote:I've used the wilwood poly 'A' pad and although they work well I'd never use them again.
Duracel79
Thanks mate.
buzz6353
Post Thu Aug 26, 2010 2:25 pm
Mintex M1144 or 55 .work well
you can use a couple of anti rattle shims with Vauxhall nova pads in some of the wilwood calipers as well
LondonTom
Post Thu Aug 26, 2010 5:58 pm
Also just to confirm - will 15 inch bbs wheels clear a 280 disc and 4 pot caliper?
e301988325i
Post Thu Aug 26, 2010 6:20 pm
yes
I said:
LondonTom
Post Thu Aug 26, 2010 6:29 pm
e301988325i wrote:yes
Thanks mate...I'm now off to unbolt these oversized wheels...a set of Azev A's in black :wink:
rix313
Post Thu Aug 26, 2010 6:55 pm
They fit nicely in 15inch wheels it's the offset you need to worry about. The caliper sits VERY close to the inside face of the BBS's. I put some 5mm spacers in to give them a little bit of breathing space.
Any pics of the car winkeye ?
LondonTom
Post Thu Aug 26, 2010 9:57 pm
rix313 wrote:They fit nicely in 15inch wheels it's the offset you need to worry about. The caliper sits VERY close to the inside face of the BBS's. I put some 5mm spacers in to give them a little bit of breathing space.
Thanks rix, there's already a spacer up front, but I think the current wheels are ET30. I'll take some pictures over the weekend.
Hopefully picking up some black BBS's next week.
LondonTom
Post Sat Aug 28, 2010 2:02 pm
Here you go:
I'm picking up some 15 inch BBS's next week, then will raise the suspension slightly and hopefully get a cage in there.
tomislav
Post Sat Aug 28, 2010 5:46 pm
Sweet rid mate, i like the look of it. You should leave it as it is!!!
rix313
Post Sun Aug 29, 2010 11:35 am
Ooft that's yummy :twisted:
