Sun Aug 22, 2010 4:18 pm
Right, i had a good look today. I`d bought a new set of shoes, but tbh it didn`t need them. Ihad the discs off and cleaned them up, tightened the handbrake adjuster nuts. Now it holds great!
- But ! I held the disc firmly, and it still moved from side to side, probably an inch, and there was a slight knocking from under the centre of the car. Could it be a prop joint worn? driveshaft,diff,etc?
Thanks.
