E34 fuel guage issue
robbo86
Post Fri Aug 20, 2010 1:00 am
Ok, I thought that like the E30 the E34 guages would have the little copper nuts on the back, which could be tightened to cure an erratic fuel guage. However the following picture from an article about changing dashbulbs shows this isnt the case!
Basically my fuel guage on my 525 gets to the last quarter, then becomes extremely erratic, sometimes dropping right down to empty, as though the power is taken away from the guage, then coming back up after a few minutes, or the fuel light coming on when its not that low! If its not that, what else could it be? Is it likely to be an easy fix?
octanejunkie
Post Fri Aug 20, 2010 8:17 am
E34's are totally different with regards to instruments. There is a guide to replacing capacitors on www.e34.net which is the usual culprit of failing gauges on these cars.
325isporttech1
Post Fri Aug 20, 2010 3:43 pm
Tbh mate when they get just below quarter of a tank the needle does tend to sink to the bottom, all the ones ive owned have done this. The best thing to go on is the petrol light...when that comes on you have 8 litres of fuel left 8)
ucpsale
Post Sat Aug 21, 2010 7:17 pm
Quarter of a tank mine had the same problem the level sender was at fault.
Post Sat Aug 21, 2010 9:52 pm
Watch out as there about 3 different types of instrument clusters
octanejunkie
Post Mon Aug 23, 2010 11:06 am
DanThe wrote:Watch out as there about 3 different types of instrument clusters
I HATE old BMW instrument clusters :evil:
Every Beemer i've had has had problems with lying or non functioning gauges...
robbo86
Post Sun Sep 05, 2010 11:40 pm
Is the level sender expensive?
