The horizontal adjustment on my electric mirrors works fine by the vertical adjustment doesn't. If I move the lever on the switch up or down it moves the mirrors horizontally aswell.
I assume since this problem affects both sides that it is the switch that is the problem.
I am unsure of how to remove the switch and don't want to find out the hard way whether it can be levered out with a screwdriver or if there is a less brutal way that works better.
Has anyone out there had a similar problem? Any help would be much appreciated.
