Few bits....
Looking for genuine BMW parts at discounted prices? Try here!
TouringMatt
Post Sun Aug 08, 2010 5:53 pm
Hello, need a quote on the following please, last 7 chassis numbers are, 3196953
Gearbox selector shaft - 23121282394 (i think thats right)
Center prop bearing - 26121226723 - is this a complete assy/bearing fitted?
I also need the two part figure of 8 exhaust clamp that attaches to the gearbox, and a manifold to downpipe gasket, 4 hole type please.
Many thanks,
Matt
TouringMatt
Post Mon Aug 09, 2010 7:27 pm
Bump :)
Cotswoldbmw
Post Tue Aug 10, 2010 11:25 am
Hi Matt
Gearbox selector shaft - 23121282394 £6.53
Center prop bearing - 26121226723 - £54.80
figure of 8 exhaust clamp £4.70 and £6.43
manifold to downpipe gasket, 4 hole type £9.64
Prices inc. VAT delivered to mainland UK
Please call our Parts Dept. on 01242 257999 and quote 37190
There is a P&P cost of £1.99 on all orders under £20
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
TouringMatt
Post Tue Aug 10, 2010 11:41 pm
Cheers Brett, can i be a pain and add some parts
25117527252 Gear Shift (1.9 Z3) £36.46
25111220600 (Plastic Ring bush) £6.08
25111220439 x2 (Plastic Washer) £0.30
25111220379 (Circlip) superseeds to 25117571899 £0.37
(above as per rix313's request)
And also gearshift rod joint, plus neighbouring o-rings and circlips, and i've read the selector rod needs changing at the same time. I did try and work out part numbers but got lost!
Many Thanks,
Matt
Cotswoldbmw
Post Wed Aug 11, 2010 11:35 am
Hi Matt
i have added all of the above to ref 37190
the prices for the short shift are correct
the rod joint and other parts required come to a total of £49.81 inc VAT
Brett
Cotswold BMW Parts
01242 335365
TouringMatt
Post Wed Aug 11, 2010 9:07 pm
All sorted, thanks for the help
Matt
Cotswoldbmw
Post Thu Aug 19, 2010 10:43 am
Thats ok. Thanks. :D
Cotswold BMW Parts
01242 335365
