car reversed into me, nice dent
asmith88
Sun Aug 08, 2010 4:25 pm
Got a nice dent on my drivers side door today, i would rather repair the door i have then replace it,
anyone know if its a big job, cost? anybody had anything similiar? its about an inch pushed in at the worst point..
heres a pic
cheers andy
1990 brilliant red 318 is
Tommek
Sun Aug 08, 2010 4:30 pm
A solution is to use PDR (Paintless Dent Removal, you can google it if you don`t know about it) if you find a PDR specialist around you, but if you find a cheap and decent door, change it.
E30 Touring
BrianBimmerHead
Sun Aug 08, 2010 4:31 pm
new door same colour bolt it straight on
silversideofthemoon
Sun Aug 08, 2010 4:32 pm
wouldnt think it would cost much to be honest like above new door bolt on drive off
formally touringandy.............driving e30 320i touring and e39 535i
asmith88
Sun Aug 08, 2010 4:33 pm
yes, but the problems with a door as i see it, are that firstly the colour is almost always a very different shade expecially in 20 year old cars.. and secondly lining the bugger up properly
toby
Sun Aug 08, 2010 4:34 pm
That is fixable and will usually be a nicer finish than a replacement door (sod that).
toby
Sun Aug 08, 2010 4:36 pm
It's a shame there's a crease because the dent may have just popped out but it looks like it will need a touch of filler to finish it and a bit of painting.
dapperdan8001
Sun Aug 08, 2010 4:40 pm
Sorry to hear thats happened fella :cry:
As toby has mentioned, the crease on the door line will never come out good enough. Happened to my mates old TT and even audi couldnt do anything with the crease.
**BANNED**
Sun Aug 08, 2010 4:41 pm
Door swapping on an E30 is very easy,once you know how!
1.Unplug the electrics.
2.Remove the clevis pin from the stay.
3.Remove the 8mm bolts from the centre of each hinge.
4.Lift door up off the bottom hinge.
Note,do not disturb the hinge bolts on either the body or the door.
You will find that the replacement door will line up perfectly,as long as it was removed in the same way.
Door 'sits' on the lower hinge,it will not fall off when the hinge bolts are withdrawn,it will sit there until it is lifted off.
Youth is wasted on the young.
asmith88
Sun Aug 08, 2010 4:45 pm
yea, thats not too bad, but then theres swapping the locks, etc..
dosent sound great to fix it now either though..
ill get it round to someone tomorrow for a quote, failing that.. new door
**BANNED**
Sun Aug 08, 2010 5:00 pm
asmith88 wrote:yea, thats not too bad, but then theres swapping the locks, etc..
To swap the lock cylinder;
1.Remove door card.
2.Peel back plastic membrane far enough to get your hand inside...
3.Using a long flat blade screwdriver,flick the 'C' clip off the back of the lock.
4,Wriggle the lock out of the door from the outside.
Re-fitting is the reverse,but make sure the alloy plate with the mico-switch on locates correctly as you feed the lock barrel into the door.
Good oppotunity to strip the latching gear out and clean/oil,then fit a new lock barrel as well.(lock barrel's come as a bag of bits and you assemble to suit your key,£20 or so from the dealer!)
asmith88
Sun Aug 08, 2010 5:08 pm
cheers mate, will look into it tomorrow
cecotto479
Caution Unreliable Seller
Sun Aug 08, 2010 7:42 pm
Daimlerman wrote: To swap the lock cylinder;
1.Remove door card.
4,Wriggle the lock out of the door from the door
5. Grovel about in the bottom of the door for the C-clip.
1981 E23 735i
Andyboy
Alpina Colada
Sun Aug 08, 2010 7:50 pm
The chances of getting a colour match are the square root of f*ck all. Your car will have been painted at some point, and so will the door you buy - it's pretty much guaranteed.
A very good dent man will make a decent job of that. Once the main big dent is popped out (let them do it!) they can sort the crease above the waistline.
If you do replace the door, expect to have to paint the whole side of the car or at least blend it into the front and rear wings and laquer it (not recommended as the red will fade under the laquer).
asmith88
Sun Aug 08, 2010 9:15 pm
sort of what i thought, depends on the price of the dent removal, i dont think it has been painted before thought
