greensuff pads!!!!!!!!!
darren318is
Post Sat Sep 24, 2005 10:24 pm
any opinions on ebc greenstufff pads................
Motorhole
Post Sat Sep 24, 2005 11:14 pm
I havn't used them myself but I have heard that they wear far too quickly for track work, and arn't particularly effective when cold on the road.
I have Group N discs from Rally Design (www.raldes.co.uk) matched with ATE pads from Euro Car Parts. They did the job round the Nurburgring, no fade over up to 3 consecutive laps. But the rest of my car is standard, and I had cheap tyres so maybe they weren't tested particulary hard. However, with the discs at 33 quid +VAT a pair, and the pads at 17 quid +vat a pair, it works out cheap.
astondg
Post Sun Sep 25, 2005 1:41 am
I had them and used them on the track for about 30 events as well as road driving for about a year and a half. The worked ok on the road for me and didn't seem to wear that quickly considering the amount of work they did and they seemed to stand up to the track work ok, I never had problems with fade. BUT when I got them replaced the guy that replaced them (who also originally installed them) said they had been overheated so he put in some different ones this time.
I would probably go with what the Zone recommends though, I think there are Ferodo DS2500 pads in the Zone Shop.
Aston
BMW E30 323i with some stuff
1:05.17 @ Queensland Raceway Sprint track
1:10.09 @ Queensland Raceway Clubman track
1:21.67 @ Morgan Park Raceway
darren318is
Post Sun Sep 25, 2005 4:33 pm
what is the difference in green and redstuff pads
Geeman
Post Sun Sep 25, 2005 4:44 pm
I've got Greenstuff on my track car and you can stop it and nearly go through the windscreen... mind you, I've also got braided hoses, grooved discs and racing fluid.
I've never had it suffer from brake fade... EVER!
On the road though, they squeak when they get warm when you're 'fairy' braking. Work best under pressure.
Giles.
stevo
Post Sun Sep 25, 2005 5:17 pm
i had greenstuff pads on my old fiesta, they worked better than standard ones when braking hard but felt no difference normaly.
i think redstuff pads are for the track, and need to heat up first for good braking
craigieeb
Post Sun Sep 25, 2005 5:19 pm
the green_stuff pads are verry good, evan better once there warm, if you were thinking of getting these pads i would suggest getting some good disc's on there aswell mate
fuzzy
He who sleeps with "Gingers"
Post Sun Sep 25, 2005 8:28 pm
hi mate , ive got the red stuff pads on the front with the greenstuff on the back, with the ebc drilled and grooved discs all around, and the difference is unbelievable,i wouldnt buy anything else.
Karan
Post Sun Sep 25, 2005 8:35 pm
ive tried most pads out there..... and i have found ferodo 3466 and ds2500 to be the best!
with a good fluid like castrol SRF
Post Sun Sep 25, 2005 8:43 pm
me mintex m1155 just like ferodo 3466's they are awsome and were good around the nurburging for 12 laps in 30oC+ heat
still doing the business now they have done over 7k and seem to have plenty of life left and my ate power disks are not getting munched by them either
Simon
Post Sun Sep 25, 2005 9:23 pm
Personally, I wasn't impressed with the greenstuff, and they shout about the low dust, but I found them awful, when I had them on my car, it was a while back, and I'm sure they've been re-designed since then.
I have read nothing but good comments about the DS2500's, especially the guys that use the track often, but they are pricey, but "you pays your money...."
darren318is
Post Sun Sep 25, 2005 10:39 pm
im getting ate powerdiscs on 4 coreners tommoro ineuroparts and hopefully getting greenstuff all round as im not a track competitor (2ce a year trackday) can i get the pads in europarts and do europarts have any other decent pads
adamS
Post Mon Sep 26, 2005 9:00 am
I had the discs and pads on the iS. Bloody brilliant in my opinion. Going from std to those was night and day.
Highly recommended
Demlotcrew
Post Mon Sep 26, 2005 9:03 am
Green stuff are rubbish i would stay clear, you might as well go for Pagid fast road pads which are better!
Andrew
