possible unplugged sensor???
juddye30
Fri Aug 06, 2010 2:23 pm
hi, i was having a general look around the engine bay and noticed tucked up behind the leads was a lead. So with tracing it back it shares the trunking for the camshaft sensor, its a 316i on a h plate, the numbers i found on it are bosch 0356914212, i was mainly what it is?? where if it does go anywhere?? :mad:
**BANNED**
Fri Aug 06, 2010 2:37 pm
This under the inlet manifold?
Youth is wasted on the young.
Banjo1981
Fri Aug 06, 2010 2:52 pm
Or is it the firing sensor off one of the sparkplugs?
juddye30
Sat Aug 07, 2010 7:22 am
i will post some pictures up today when it stops raining, thank you fo rthe response already thought :)
juddye30
Sat Aug 07, 2010 7:56 am
Image[/img]
**BANNED**
Sat Aug 07, 2010 8:07 am
That should be on one of the plug leads,but on a four cylinder engine I cannot say which one!
It works like a cam position sensor on a more modern engine,and tells the engine ECU which injectors to fire.
juddye30
Sat Aug 07, 2010 8:51 am
i really dont mean to sound but i mainly know vauxhalls and fords inside out :roll: actually on the lead do you mean??
**BANNED**
Sat Aug 07, 2010 9:08 am
That's right,the hole in the sensor is H/T lead size,then it can read when that lead is firing it's plug.
I am unable to find out from my Haynes manual just which lead the sensor should be on,and at the moment both of my E30's have 'proper' engines!
Sat Aug 07, 2010 9:26 am
Fairly sure it should be on lead 4.
Some muppet has probably fitted (almost certainly completely unnecessarily) aftermarket leads to your car at some time.
Best plan is to get a genuine set from a scrapper, or from one of the traders on here.
juddye30
Sun Aug 08, 2010 4:01 pm
cheers thank you for all your help and time much appreciated
lol yeah i kno, its a shame but thats all i could insure at this moment in time however the body and chassis is clean so will build on the base in time that has been my plan
Tommek
Sun Aug 08, 2010 4:54 pm
if you buy new leads PM me because my sensor is broken and maybe we can make a deal.
E30 Touring
