im messing around with mapping/chipping/etc the M20 and ive got some very good maps but im noticing none deviate much from the standard WOT ignition curves. there is more advance but the curve remains nearly the same shape.
reading up on ignition timing and all that u would think the curve should basically start off low and rise as the revs rise, maybe not a straight line but something alot smoother than the standard and majority of performance maps shape wise.
im wondering is there any reason for the wierd shaped ignition maps?
here is a screenshot i took comparing standard to a good performance map and then something i reshaped to be more like what u would think the map should be like. quite a difference looking at them. any ideas why the standard and performance maps like to stay with this up/down shape of ignition map? im probably going to experiment with something similar to the curve i made below to try and figure out why its shaped like it is and not in a more traditional curve/line shape.
