325 SPORT DIFF, WILL DRIFT LEFT BUT IS JUMPY TO THE RIGHT
Big_M_
Post Sun Sep 25, 2005 12:37 am
CAR WILL DRIFT TO LEFT A1 BUT WHEN DIFTING RIGHT THE WHEEL STARTS AND STOPS SPINNING, ANY IDEA'S ON WHERE TO GET A CLUTCH PACK FOR THE DIFF AND IF POSSIBLE SOME INFO ON FITTING THE CLUTCH PACK.
jmc330i
Post Sun Sep 25, 2005 10:44 am
First off, welcome to the Zone :thumb:
No idea where to get the clutch pack from. There are specialists out there who rebuild LSDs.
When you say the wheel stops and starts spinning, are you sure thats what its doing?
From the thread title you said its 'jumpy' so I would look at your rear suspension first. Could be the rear shock mount has given up. Both of mine broke and I had the rear wheels jumping under hard acceleration/wheel spin.
You will need to replace both and using the E46 M3 Cab rear shock mounts is a common upgrade for the E30.
BTW - Writing with Caps lock is considered shouting on forums by some people.
James
'91 325i Sport
'93 318i touring 16v
Martinaston
Post Sun Sep 25, 2005 11:35 am
These guys look like they know there stuff, don't look cheap though
http://www.quaife.co.uk/products/atbdifferentials.htm
There is NO nucleus.
M3Compact
Post Sun Sep 25, 2005 12:56 pm
Quaife ATBs are ace imo, but not as good as the BMW ZF LSD unit for drifters, because they never actually lock.
I've not found anywhere that supplies clutch packs, but you can use Ford Atlas clutch packs. (These are Ԛ£120 a set, but you get 4 plates instead of just 2.)
stuartgallafant
Post Sun Sep 25, 2005 1:17 pm
Why does everyone put e46 rear top mounts on e30's?
I keep seeing/hearing that people have done this, I just wanna know the advantage!
Let me know...
Cheers dudes
M3Compact
Post Sun Sep 25, 2005 1:32 pm
stuartgallafant wrote:Why does everyone put e46 rear top mounts on e30's?
Let me know...
Cheers dudes
They're stronger/more durable/last longer.
E46 M3 Cabriolet mounts. 8)
Big_M_
Post Sun Sep 25, 2005 3:30 pm
Thanks for the welcome and the cap letters tip, e30 zone is A1. Will have a look at the mounts and maybe replace them anyway as i'm installing powerflex bushes all round soon. when it starts to jump its like the wheel is slipping and then getting grip if you get me. Is there much to fitting the e46 mounts or do they drop straight in.
jmc330i
Post Sun Sep 25, 2005 5:15 pm
Big_M_ wrote:when it starts to jump its like the wheel is slipping and then getting grip if you get me. Is there much to fitting the e46 mounts or do they drop straight in.
Sounds like the wheel is actually jumping or skipping off the ground when its spinning, like mine were.
The E46 mounts are a direct replacement for the E30 ones.
James
'91 325i Sport
orangecurry
Post Sun Sep 25, 2005 9:46 pm
'...when it starts to jump its like the wheel is slipping and then getting grip if you get me. ...'
are the tyres the same (make/depth) on both sides of the car? (call me old fashioned)
M3Compact
Post Sun Sep 25, 2005 9:57 pm
'Tramping'? (Allowing movement in the mountings, that 'springs' on and off.)
Big_M_
Post Mon Sep 26, 2005 10:17 pm
thanks for the replies lads but its not so much that the wheel is bouncing but the car sort of lunges fwd in jumps, like your having a bad day on and off the clutch. so it feels like the wheel is spinning like it should and then gets grip which pushes the car forward then looses traction spins again and give this car lunging forward feeling. sorry for the long thread but hard to put words to you.
