Dial on the back of the OBC
smithy318i
Post Sat Sep 24, 2005 6:35 pm
Anyone know that the dial on the back of the OBC is for !
Well ill tell you...
it changes from a combination of Deg C/ F and the 12 /24 hour clock.
billgatese30
Post Sat Sep 24, 2005 6:37 pm
which obc is this 6 button or 13 button
smithy318i
Post Sat Sep 24, 2005 6:43 pm
6 button
but dont see why it should be different to the 13
billgatese30
Post Sat Sep 24, 2005 6:47 pm
well, on the 13 button obc there is a little hidden buttoin on the front that you get at woith a pen to change this, just making sure that it doens't have another switch that changes it in another way.
gcorky
Boost Junkie
Post Sat Sep 24, 2005 7:10 pm
does the 13 btn usually change from deg c-f on the little button on front?mine is on f,but would like c.also does it only display avg speed and not actual?
smithy318i
Post Sat Sep 24, 2005 7:38 pm
The anoying thing about pressing the little button on the OBC is you can only have Deg F and miles OR Deg C and KM.
but i think the switch on the back changes that.
gcorky
Boost Junkie
Post Sat Sep 24, 2005 7:40 pm
off topic smithy sent pm about cards/meet 8O
billgatese30
Post Sat Sep 24, 2005 8:57 pm
not sure about switch on the back, thats why i wondered, as i would like miles (m/g) and degrees c
to change it you have to put it on consumption, then press it till it shows L/100 , then the temp will be in C
and yes, it is only average speed, not actual
gcorky
Boost Junkie
Post Sat Sep 24, 2005 9:41 pm
good all is well then :cool:
Simon
Post Sun Sep 25, 2005 10:15 am
smithy318i wrote:Anyone know that the dial on the back of the OBC is for !
There should be 3 combinations, this is only available on the 6 button, with the 13 button, there is no way to adjust it, the dial on the back of the 13 button is for configuration iirc.
