x-works
Sat Jul 24, 2010 12:41 pm
Thats most of the main loom fitted, theres probably more, but sure if I
showed it all it would take all the fun out of you fitting your own.
Plus it's over two months since I fitted all that crap, and I've been
guessing most of what you've just read.
There's quite a few mini looms that plug into the main chassis loom once
fitted such as this one. It has the wiring for the stereo, hazard light switch,
electric window circuit breaker switch, glove box light and so on........
the ignition switch......
indicator and wiper stalks.........
a quick note on these last two by the way, took me a fu*king eternity
to figure this one out. Theres a little bracket welded onto the steering
column coloured red below.........
and when the ignition switch loom is plugged into the chassis loom
the plug clicks into this little bracket...........
and then when the wiper/indicator plug is reattached.......
it slides in and clicks in to place above the ignition plug............
and fu*k it, thats enough wiring, me head is melted.
And it's also enough for this update.
I promise the next one won't be quite as boring as we tackle the art of removing
carpet dye from bare skin, nailing on a pair of side skirts, modifying a rear parcel
shelf and loosing the will to live while fitting a roof cloth.
Should have it up in the next few days.
Till then...........
CaesarBob
Sat Jul 24, 2010 1:11 pm
Epic as usual ... keep it coming.
'97 E36 B3 3.2 Touring - Alpina-Blau
'15 F32 420d M Sport Coupe - BMW - melbourne-metallic (Sold)
'11 E92 320d M Sport Coupe - BMW-saphirschwarz-metallic (Sold)
'99 E36 328iA SE "Shooting Brake" - BMW-titansilber-metallic (Sold)
'89 E30 325i
Nay
- Channel Island Crew
Sat Jul 24, 2010 4:32 pm
That looked like a proper ball ache!
At least its one more major part done!
Uni is killing the project.
lenny-d
x-works
Sun Jul 25, 2010 1:53 pm
With the wiring all in, the next thing to do was get the carpet in on top
of it. Despite being 20 odd years old the carpet was in remarkably good
condition. A shampoo and steam clean left it looking as good as new.......
Only one small problem with it, it was grey, I want it black.
So, a gallon of Valeters Pride black carpet dye (e-bay £25)........
an old squirter bottle..........
and a soft-ish nail brush.........
Spray the stuff on the carpet, gently rub it in with nail brush and leave to
dry. Reapply a second coat if needed. It doesn't take a great deal of the
dye to do the job, I only got through about one litre to do it all.
Tried it out on a spare bit of carpet first, just to check it wasn't going
to go arse ways and make a balls of me good carpet. Test went well
so on to the real thing.........
Wasn't sure how the vinyl/plastic bits of the carpet were going to take
to the dye but as it turned out they dyed perfectly black too........
With the carpet all dried out (24 hours for full non-smudge dryness)
it could go back into the car.....
With the carpet in the dash and centre console could also go back in.........
pretty straight forward this, only one little mod to do on the clocks unit......
it didn't seem right having the odo reading 185,000.........
For this next part I'll be forever greatfull to DanThe,
about a year ago I received a pm from him to say he had an unused
black non sunroof headcloth for an M3 if I wanted it. Seeing as these are
NLA from the main dealer for years now it wasn't a difficult decision..........
No pictures of the job in progress as it was a complete swine to do.
However the hardship was worth it as it came out nice in the end........
should have the rest of this update up later on this evening.
Till then.........
CaesarBob
Sun Jul 25, 2010 7:59 pm
Out of curiousity, how did you reset the mileage?
'89 E30 325i
x-works
Sun Jul 25, 2010 10:31 pm
Out of all the work posted up on this build thats the one tiny bit
thats not being detailed. I'm sure you'll understand the reasons why.
Sorry.
p/s I'm sure theres other members that have done this task
and I'd appreciate if the details weren't posted up in this
thread.
Thanks folks
x-works
Sun Jul 25, 2010 10:42 pm
Carpets in, next up was the rear parcel shelf. Below you can
see the original parcel shelf complete with the holes cut out
for the speakers the previous owner fitted.......
And if you cast your mind back a bit you might remember
when the bodywork was been finished off I made up some
speaker enclosures and welded them into the rear bulkhead........
now, a smart person probably would have measured the hole's in the parcel
shelf and welded them enclosures in to match up, so the parcel shelf
would be a straight forward refit. However, it would appear I'm not the
brightest star in the sky, as when I went to offer the parcel shelf back
into place the holes were a mile off......
So, the solution. Remove the sound proofing from under
the parcel shelf........
butcher a big hole out of the centre of it and replace with a thin piece of
aluminium...........
check measurements 15 times before cutting holes in the aluminium.......
drill and screw alum down to parcel shelf to hold it tight in place till
the adhesive underneath dry's..........
fit in place to check everything lines up..........
While it all fitted up nice and snug now there was still the small problem
of bare aluminium not being at the cutting edge of custom car interior design.
So, a little material..........
chop, chop......
glue explosion.........
sticky fingers, lost scissors.......
Bingo.......
the M3 having the extended rear windscreen section also has another
little added section of parcel shelf to fill up the gap so this got covered too......
All done, time to bang it back in and fit the speakers and rear seatbelts,
and this is how it came out...........
more tomorrow.
Till then...............
x-works on Sun Jul 25, 2010 10:59 pm, edited 1 time in total.
Sun Jul 25, 2010 10:48 pm
Who'd have thought 6x9's could look 'right' in an E30?
Morat
Sun Jul 25, 2010 10:54 pm
Being a touring perv myself... what are the little vents at the rear of the parcel shelf for?
Great updates
Sun Jul 25, 2010 10:56 pm
6x9 wrongness on a superb car like this
buy some BMW premiums please ?
CaesarBob
Sun Jul 25, 2010 10:58 pm
x-works wrote:Out of all the work posted up on this build thats the one tiny bit
Sorry.
thread.
Thanks folks
Sorry, wasn't looking for a step-by-step guide.
Was really just asking if they are the original clocks rather than a new ones.
'89 E30 325i
x-works
Royalratch
Tue Jul 27, 2010 2:08 pm
16x9's and 17's.
I guess the standard of work has been so awesome and helpful you're allowed a few deviations...
Nay
Wed Jul 28, 2010 2:11 pm
Royalratch wrote:16x9's and 17's.
A piece of work this awesome diserves some smart shoes. And they're BBS so its not that far out.
16x9's though!
Dezzy
- CR24v it's a lifestyle
Wed Jul 28, 2010 3:00 pm
I love this thread.
I am with Dan them speakers look fine to me. Lovely car this.
The wheels are going to look right on your car too.
Co Founder of
CR24vTM By Invitation Only. Absolutely no riff raff!!!
x-works
Wed Jul 28, 2010 10:26 pm
With the car now back on the ground it was time to super glue the side
skirts back on. I don't know who back in the day designed these skirts
for the M3, but who ever it was certainly took their job seriously.
I've seen small bloody aircraft wings that didn't use this many fittings
to secure them. First up was these little green grommets below
p/n 51711932996. Seven of these are needed both sides, giving a total
of 14. As you can see below I bought 18 because, obviously, I can't count..........
and 4 of these little black washers p/n 51711922599.
One black one at either end and seven green ones in the holes in between......
Then there's the little white dudes that are going to pop into the green grommets.
P/n 51711936517, 7 of these for each side............
these pop onto the top inside lip of the skirts, shown below.........
and then theres 4 of these that also go on the skirts, one at each end.
(I'm starting to think one of the previous owners of this car must have
been a f*ckin mermaid who lived at the bottom of the sea).............
anywho p/n 51711933719..........
these slide into the little slots each end of the skirt..........
and when the skirts are offered up to the car the white clips click into
the green grommets and the steel clips are secured at either ends by 4
little plastic nuts.......
nuts are filled with a little grease in the naive thought that this might prevent
them being such a b*stard to remove in the future..........
each skirt gets 3 little push pegs to secure it as well
(obviously to bring them up to full hurricane proof specification)
two at the rear of each skirt..........
and 1 above the rear jacking point.............
and finally 5 of these little plastic clamps (51711933125) are fitted to
the bottom lip of each skirt to secure it........
bit of grease on the face of these should stop them trapping
dirt and then dampness up against the bodywork which will
eventually lead to rust.........
I bought some stainless screws for attaching these instead of the factory
screws as I had immense hardship removing the rusted old ones.......
Screws screw in from the front of the skirt into the plastic clamp,
clamping the bottom of the skirt to the bottom sill.
and the end result? a pair of skirts which are well enough secured to
survive a direct nuclear strike..............
Should have the final episode of this update up tomorrow, the
glass fitting, and some pictures of the rear end which almost
looks like a complete car again, if you squint through one eye,
and catch it at the right angle, a little, kinda.
x-works on Wed Jul 28, 2010 10:32 pm, edited 1 time in total.
The_Diddler
- Love it up the more door !
Wed Jul 28, 2010 10:30 pm
Great thread, great work and attention to detail, stunning
Wed Jul 28, 2010 10:39 pm
Wont be long now
Please tell me you plastered these with waxoil before fitting?
Wed Jul 28, 2010 10:45 pm
Great work. Where did you get the stainless steel screws from?
CaesarBob
Thu Jul 29, 2010 12:47 pm
(I'm starting to think one of the previous owners of this car must have been a f*ckin mermaid who lived at the bottom of the sea).............
Quality!
Just noticed the date stamp on most of these piccies. Does that mean you actaully finished the car months ago and haven't revealed the finished product yet?
CaesarBob on Fri Jul 30, 2010 3:07 pm, edited 1 time in total.
'89 E30 325i
jalfa
Fri Jul 30, 2010 3:02 pm
Absolutely awesome.
I've only just joined the zone... and due to this thread I already want to dismantle my car, refurb every bit and put it all back together perfectly. Really inspiring stuff!
Jon_Bmw
- Dangerous when thinking
Fri Jul 30, 2010 7:05 pm
Looks very good X works. Out of interest do you have a credit account at BMW?
I expect you spend as much with them as most independant bodyshops!
Are the side skirts 'matt' on an m3 normally, I can't really remember. Either way it will look good.
x-works
Fri Jul 30, 2010 9:56 pm
And eventually we arrive at the final episode of this update. Glass.
The original front windscreen at 20 odd years old, looked like it had been
shot at close range with a blunderbus elephant gun. Every square inch was
covered in little chips. So it's being replaced with a new one. The windscreen
is aftermarket and is made by a crowd called Pilkington. Which means its a lot
cheaper than from Bmw and also as good a quality. There seems to be a few choices
of tint levels and I went with the green with dark green sun strip at the top as
this was identical to what was removed...........
No pictures of during the task i'm afraid, but the one little thing to
be careful of though is that the little drain holes at the bottom of the
windscreen surround don't get blocked up with the sealant/adhesive gue.
With the front one in, it was on to the rear screen which is slightly more involved.
Theres two trim strips that fit around the rear screen and I was sure that these
could be fitted after the screen was in, however, as usual I was wrong........
on the back side of the trim strips theres a load of little slots........
and this is the reason why. 18 of these little plastic clips below are fitted
to the outside edge of the screen (p/n 51318177850 sold in pack of 20).
They've a little sticky pad on them to bond to the screen.......
The only catch is they've to be stuck in exactly the right place to match
up with the slots in the trim peices. I was a bit lucky in this regard, as
this is the original windscreen that was cut out intact and is good to go
back in again. The old clips broke to pieces upon removal but there was
still marks on the screen where they were fitted, so the new ones just had to
go back on to the same place............
With the clips on, the 2 trim pieces could be snapped down onto them
and with a fat bead of adhesive on the rear of the screen it was thrown into
place.........
nearly forgot, theres two other little plastic pegs that sit at the bottom
between the glass and the bodywork. They're hexagonal in shape and you
can twist them with a flat screwdriver while the adhesive is still wet to
3 different heights to help set the windscreen trim gaps right with the
surrounding bodywork.........
Screens in, it was on to the rear side glass........
glass sits into its rubber..........
and then the shadow trim needs to be fitted to the outside of the rubber.......
on the inside of the trim theres a raised edge..........
and this edge needs to sit into this groove in the rubber...............
to lessen the chances of a hammer being taken to the glass during this job
out of rage, we use some lubricant, in the form of some washing up liquid
watered down a little bit.........
Once your not stingey with the washing up liquid its usually fairly simple
to massage the rubber enough to get the trim to slot down into its groove.......
last bit to go on is this little strip of rubber which slides up on the front
edge of the trim.............
x-works
Fri Jul 30, 2010 10:04 pm
to look like so.........
and then on to the small matter of battering the window into place.
Both "B" and "C" pillar trims need to be in place inside first..........
and then the rubber needs to be lubed up (no matter what way you
type that it still ends up sounding like a ropey porn film).............
and then we need a length of electrical cable, nice and skinny, a single
strand of speaker cable usually does the job..........
wrap the cable around the rubber so that it sits into the groove that was
just soaped up.........
and then finally plaster the metal edge in the window frame that the rubber
sits over with plenty of soap as well............
The next bit is a two man job, it can help if your assistant is smaller than
you and has a peaceful nature, that way you can bollock him if the job
starts to go wrong without fear of having your nose broken.
The window is held tightly up against the frame making sure that the 2
threaded bolts (arrowed below) have entered their holes on the "B" pillar........
and if your assistant has held the window in just tight enough so that the
rubber is a little squashed against the frame, when you start to pull the speaker
cable through from inside the car, it'll pop the rubber lip over the frame rail in
the process.............
and voilla, the windows fitted. Screw up the 2 nuts on to the frame bolts
that went into the holes on the "B" pillar and thats it. Make sure to thank
your assistant before blaming him for any scratches on the outside bodywork
that you made months ago..............
With the window in, the external "C" pillar trim can now go on........
First up you gotta attach the shadow trim piece to the painted piece
with the aid of these 5 little thingamajigs..........
they just pop into the 5 little holes on the painted piece...........
and then the centre peg is bashed down to spread the underneath piece
so that they don't fall off again while your doing 100 on the motorway.......
with these in place the shadow trim piece just snaps down onto them.
Then you need 6 of these little dudes (3 for each side of the car)
p/n 51131870459.........
which fit into the "C" pillar (red arrows) and another little pair of grommets
(one for each side) to go in at the blue arrow..........
On the back of the trim piece there's 4 little dowels which pop in to
the grommets above, to hold the trim on to the car. The dowels are
fragile and the grommets are tight so you've gotta be real gentle fitting
them.............
With all the rear glass in, the rear bootlid could go back on and the rear
bumper. Which leaves the car currently looking like this...............
And thats about all for now. She's starting to come back together
now, and the pace is getting a little quicker as the finishing post is
in sight (lets face it, it couldn't go any slower). The interior is due back from
retrim in the next week or so and then the doors can be rebuilt and refitted.
So it shouldn't be as long till the next update.
Maybe.
x-works on Sat Jul 31, 2010 11:04 am, edited 1 time in total.
Royalratch
Gortour
Sat Jul 31, 2010 10:44 am
F**king AWESOME with a capital A...
nickso
- Location: Go do that voodoo that you do so welllllllll!!
Sat Jul 31, 2010 5:18 pm
fabulous thread. i'm almost sad it's nearing the end.
don't use washing up liquid as a lubricant though. it's full of salt apparently.
'88 e30 328i M52 track bint.
x-works
Sun Aug 01, 2010 10:04 am
Thanks again folks for all the kind words, much appreciated.
Morat
I'm not sure to tell the truth, if I had to guess I'd say probably
to encourage airflow inside the car from the front to travel out
along the rear parcel shelf and into the boot to exit out through
the vents behind the rear bumper. And in the process keep
the rear windscreen from misting up.
Covered them in grease, same job but easier to apply.
I bought all the stainless screws, nuts and bolts used from a local
bolt supplier. If your after some yourself and can't find a supplier
locally then e-bay is full of people selling them.
CaesarBob
actually finished the car months ago and haven't revealed the finished
product yet?
unfortunately, no. I'm just the slowest worker on this forum.
Theres a good chance most of us will be drawing the old age
pension when this thing eventually gets finished.
jalfa
Welcome aboard. Thats a large part of the reason I posted most
of this boring crap up. These cars were made back when the
designer was king of the castle in the factory, unfortunately
nowadays it seems the accountants have taken over, hence the
bland soulless boxes you see driving around. Hopefully this
thread will help keep a few more e30's on the road and in good
condition.
Jon_Bmw
I now have my own personal reserved parking space at the
dealer. They've kindly labelled it "Sucker".
Are the side skirts 'matt' on an m3 normally?
They are indeed, I prefer the gloss look hence the change during
repainting.
Gortour
f**king Thank you with a capital T......
Nikso
Think this has been overly exaggerated by people who would
like to sell you car cleaning products. As long as you don't
apply it directly to bare metal then it shouldn't be an issue.
I'm sad it hasn't finished a year ago!
nickso
Sun Aug 01, 2010 7:22 pm
x-works wrote:Nikso
thats a severe possibility.
the only reason i mentioned it was all the high heid yins in my profession (domestic gas gubbins) get a big hard-on when folks use washing up liquid to soapy joints and test for leaks. TBH i can sit on the fence as i've seen joints that only i have soapied with the proper stuff look corroded.
also, if this thread and your resto had finished a year ago it wouldn't have been anywhere near the standard it is now......chin up my good man.
snakebrain
Gortour
Thu Aug 05, 2010 7:29 pm
Keep bumping it then, keep it at the top... lol
