major transformation well done
323i Black Chromie project update bit of a sad news
15" BBS FTW ,
Use a 325 gearbox and a 325 radiator. Just make sure you dont buy the switchable box if yours is not. Also you might need to modify the oil pipes coming from the radiator to the gearbox i had some new ones made only £8 eachsrmalek wrote:hi, just a quick one, i just bought a 323 (auto) with faulty gearbox, any addtional parts should be modified just to fit in the 325 box? or can i use 318 box instead?
Ok thanks for the info, why should i use a 325 radiator ? because i just bought a new radiator and fitted it in my 323, and sorry im new to this e30, what's a switchable box? cheersandreia wrote:Use a 325 gearbox and a 325 radiator. Just make sure you dont buy the switchable box if yours is not. Also you might need to modify the oil pipes coming from the radiator to the gearbox i had some new ones made only £8 eachsrmalek wrote:hi, just a quick one, i just bought a 323 (auto) with faulty gearbox, any addtional parts should be modified just to fit in the 325 box? or can i use 318 box instead?
A switchable box is an Auto 'box, with 3 settings-sports mode, econ.mode & 1,2,3. Theres a switch on centre console for selecting these functions If your 'box isn't switchable, I would imagine retro fitting would be a nightmare.
BTW your car is stunning.
You can use your old radiator, but, the oil fittings on the 325 gearbox they youl be diffrent the what you got on the car at the moment so they will not be a straight fitt, I have a radiator from a 325 with aircon an i find i got better cooling on my carsrmalek wrote:Ok thanks for the info, why should i use a 325 radiator ? because i just bought a new radiator and fitted it in my 323, and sorry im new to this e30, what's a switchable box? cheersandreia wrote:Use a 325 gearbox and a 325 radiator. Just make sure you dont buy the switchable box if yours is not. Also you might need to modify the oil pipes coming from the radiator to the gearbox i had some new ones made only £8 eachsrmalek wrote:hi, just a quick one, i just bought a 323 (auto) with faulty gearbox, any addtional parts should be modified just to fit in the 325 box? or can i use 318 box instead?
I had to sell my cromie due to the gearbox going. No time and no funds meant it had to go. At least i know it went to a good home and it will be on the road in no time
Life goes on and so i decided to buy another E30 from chealseaboy
325i manual
mick_318is
New Car looks nice.
however I did prefer the old one ! Old skool
E30less again.
ChelseaBoy
I know, it was so under rated by potential buyers on the zoneandreia wrote:Mate this is such a great carChelseaBoy wrote:Missing Kofi
